Is robot_state_publisher designed to handle multiple sources of /joint_state information? For example, let's say I have the R2D2-like robot from this tutorial. If I have one node publishing the state of the 'periscope' on /joint_states, and another node publishing the rest of the joints, also on /joint_states, will robot_state_publisher do the right thing? (i.e., 'merge' the /joint_state messages?).
I'm currently studying the source code to definitively figure this out, but I see that others have asked this in the past, so I figured I'd raise the issue again.
Originally posted by Rick Armstrong on ROS Answers with karma: 567 on 2017-09-10
Comment by ahendrix on 2017-09-10:
I think this will work but I'm not certain.
Comment by Rick Armstrong on 2017-09-10:
After looking at the source, I think so, too. I'll post my result after I get it working (or don't) :)
Comment by gvdhoorn on 2017-09-11:
Yes. This is designed to work like this afaik.
An alternative could be to use joint_state_publisher with the source_list argument. It will merge all JointState msgs on the specified topics and publish a single representative one.
Yes, this definitely works, we've been using different robots with different nodes contributing to joint states and all getting fed into one robot_state_publisher for years.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2017-09-11
Minor perhaps, but @Rick Armstrong describes a setup where multiple JointState publishers feed a single robot_state_publisher. Having a single joint_state_publisher merge multiple JointState msgs into a single one (via source_list) is slightly different.
Comment by Stefan Kohlbrecher on 2017-09-12:
Arg, I actually meant robot_state_publisher and mistyped. Fixed now.
Comment by Rick Armstrong on 2017-09-17:
Side note for fellow dunces: if you forget to populate JointState.header.timestamp before publishing, robot_state_publisher will quietly drop your JointState messages (unless you set ignore_timestamp to true).
