Dear all,
can I start somehow two different Rviz instances which run on two different PC but connect to the same ROS master?
I have one ROS master running ROS Indigo. There I am running different tools to control a robot. Now I would like to connect with a second Linux PC to the first ROS master and start another Rviz instance to see the current state of the robot. Is this possible and if yes, how do I have to specify the command on the second PC?
Best matl
Originally posted by matl on ROS Answers with karma: 13 on 2017-09-05
Comment by jayess on 2017-09-05:
Have you tried using rosrun rviz rviz on both and seeing what happens?
Comment by matl on 2017-09-08:
Thanks for the hint, I also had to do the export ROS_MASTER_URI=myipadress to conenct it to the master. But anyway I have trouble to see the robot in the second PC. In Rviz I still cannot see the robot. Please see the uploaded picture which I did: https://ibb.co/fD1LjF
Comment by jayess on 2017-09-08:
You should really update your answer with a proper screenshot vs a picture of your monitor taken with a camer/cellphone.
sorry, the PC is right now not connected to the internet so it was the only chance to get some kind of screenshot
Just use rosrun rviz rviz on both computers. Should work.
Originally posted by jayess with karma: 6155 on 2017-09-05
Yes it is possible and you don't have to do anything special, just start it like normal. Are you having problems trying it?
Originally posted by Airuno2L with karma: 3460 on 2017-09-05
Like mentioned above, I found one small operator misstake ;-) but I still do not see the whole robot: https://ibb.co/fD1LjF
Comment by Airuno2L on 2017-09-08:
That sounds like a new unrelated problem that we don't have enough information to help with yet. I'd open up a new question that describes the problem in more detail.
As a tip for the future, it's best to do actual screenshots rather than a photo of a screen, and post the actual screenshot rather than a link to it, I think it increases your chances of getting people to help.
