I want to control a servo attached to arduino by subscribing to /joint_states topic so that when the change the slider position the servo moves accordingly. I tried with the following code but the servo doesn't change its position when i change the slider position on rviz. The led on Arduino blinks as written in the callback function but the servo isn't moving.
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
#else
  #include <WProgram.h>
#endif
#include <Servo.h>
#include <ros.h>
#include <std_msgs/UInt16.h>
#include <sensor_msgs/JointState.h>
ros::NodeHandle  nh;
Servo servo;
double ang=0;
void servo_cb( const sensor_msgs::JointState& cmd_msg){
  ang=radiansToDegrees(cmd_msg.position[0]);
  servo.write(ang); //set servo angle, should be from 0-180
  digitalWrite(13, HIGH-digitalRead(13));  //toggle led
ros::Subscriber<sensor_msgs::JointState> sub("joint_states", servo_cb);
void setup(){
  pinMode(13, OUTPUT);
  nh.getHardware()->setBaud(115200);
  nh.initNode();
  nh.subscribe(sub);
  servo.attach(9); //attach it to pin 9
void loop(){
  nh.spinOnce();
double radiansToDegrees(float position_radians)
  position_radians = position_radians + 1.6;
  return position_radians * 57.2958;
Originally posted by Yogi_4 on ROS Answers with karma: 38 on 2017-08-31
Comment by lagankapoor on 2018-01-15:
@Yogi_4 may you help me for this ?
Comment by Yogi_4 on 2018-01-16:
What is the issue? @lagankapoor
Comment by lagankapoor on 2018-01-18:
I have one Lynxmotion Arm and i want to use that with MoveIt , if any more detail needed please visit my new question that i post today
I got it solved issue was with baud rate
Originally posted by Yogi_4 with karma: 38 on 2017-09-01
