I followed: http://rtt-lwr.readthedocs.io/en/latest/tutos/orocos-tuto.html
instructions:
cd ~/code/ros_kinetic/src/
catkin_create_pkg my_component rtt_ros roscpp ocl rtt_sensor_msgs
roscd my_component
src:
vim src/basic_orocos_rtt.cpp
#include <rtt/RTT.hpp>
#include <rtt/TaskContext.hpp>
#include <rtt/Component.hpp>
#include <rtt/Logger.hpp>
class MyComponent : public RTT::TaskContext
   public:
   // Constructor
   // That's the name you're gonna pass as first argument of "loadComponent"
   MyComponent(const std::string& name):
   RTT::TaskContext(name)
        RTT::log(RTT::Info) << "Constructing ! " << RTT::endlog();
   // The function called when writing my_component.configure()
   bool configureHook()
        RTT::log(RTT::Info) << "Configuring  ! " << RTT::endlog();
        return true;
   // The function called (periodically or not) when calling my_component.start()
   void updateHook()
        RTT::log(RTT::Info) << "Updating ! " << RTT::endlog();
ORO_CREATE_COMPONENT(MyComponent) //Let Orocos know how to build this component
CMakeLists.txt:
project(my_component)
## Compile as C++11, supported in ROS Kinetic and newer
# add_compile_options(-std=c++11)
## Find catkin macros and libraries
## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
## is used, also find other catkin packages
  roscpp
  rtt_sensor_msgs
  rtt_ros
  cmake_modules
## System dependencies are found with CMake's conventions
# find_package(Boost REQUIRED COMPONENTS system)
## Uncomment this if the package has a setup.py. This macro ensures
## modules and global scripts declared therein get installed
## See http://ros.org/doc/api/catkin/html/user_guide/setup_dot_py.html
# catkin_python_setup()
## Declare ROS messages, services and actions ##
## To declare and build messages, services or actions from within this
## package, follow these steps:
## * Let MSG_DEP_SET be the set of packages whose message types you use in
##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
## * In the file package.xml:
##   * add a build_depend tag for "message_generation"
##   * add a build_depend and a run_depend tag for each package in MSG_DEP_SET
##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
##     but can be declared for certainty nonetheless:
##     * add a run_depend tag for "message_runtime"
## * In this file (CMakeLists.txt):
##   * add "message_generation" and every package in MSG_DEP_SET to
##     find_package(catkin REQUIRED COMPONENTS ...)
##   * add "message_runtime" and every package in MSG_DEP_SET to
##     catkin_package(CATKIN_DEPENDS ...)
##   * uncomment the add_*_files sections below as needed
##     and list every .msg/.srv/.action file to be processed
##   * uncomment the generate_messages entry below
##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
## Generate messages in the 'msg' folder
# add_message_files(
#   FILES
#   Message1.msg
#   Message2.msg
## Generate services in the 'srv' folder
# add_service_files(
#   FILES
#   Service1.srv
#   Service2.srv
## Generate actions in the 'action' folder
# add_action_files(
#   FILES
#   Action1.action
#   Action2.action
## Generate added messages and services with any dependencies listed here
# generate_messages(
#   DEPENDENCIES
#   std_msgs  # Or other packages containing msgs
## Declare ROS dynamic reconfigure parameters ##
## To declare and build dynamic reconfigure parameters within this
##   * add a build_depend and a run_depend tag for "dynamic_reconfigure"
##   * add "dynamic_reconfigure" to
##   * uncomment the "generate_dynamic_reconfigure_options" section below
##     and list every .cfg file to be processed
## Generate dynamic reconfigure parameters in the 'cfg' folder
# generate_dynamic_reconfigure_options(
#   cfg/DynReconf1.cfg
#   cfg/DynReconf2.cfg
## catkin specific configuration ##
## The catkin_package macro generates cmake config files for your package
## Declare things to be passed to dependent projects
## INCLUDE_DIRS: uncomment this if you package contains header files
## LIBRARIES: libraries you create in this project that dependent projects also need
## CATKIN_DEPENDS: catkin_packages dependent projects also need
## DEPENDS: system dependencies of this project that dependent projects also need
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES sam_basic_orocos_rtt
#  CATKIN_DEPENDS roscpp rtt_ros_integration
#  DEPENDS system_lib
## Build ##
## Specify additional locations of header files
## Your package locations should be listed before other locations
include_directories(
# include
  ${USE_OROCOS_INCLUDE_DIRS}
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/sam_basic_orocos_rtt.cpp
## Add cmake target dependencies of the library
## as an example, code may need to be generated before libraries
## either from message generation or dynamic reconfigure
# add_dependencies(${PROJECT_NAME} ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
## Declare a C++ executable
## With catkin_make all packages are built within a single CMake context
## The recommended prefix ensures that target names across packages don't collide
# add_executable(${PROJECT_NAME}_node src/sam_basic_orocos_rtt_node.cpp)
## Rename C++ executable without prefix
## The above recommended prefix causes long target names, the following renames the
## target back to the shorter version for ease of user use
## e.g. "rosrun someones_pkg node" instead of "rosrun someones_pkg someones_pkg_node"
# set_target_properties(${PROJECT_NAME}_node PROPERTIES OUTPUT_NAME node PREFIX "")
## Add cmake target dependencies of the executable
## same as for the library above
# add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
## Specify libraries to link a library or executable target against
# target_link_libraries(${PROJECT_NAME}_node
#   ${catkin_LIBRARIES}
## Install ##
# all install targets should use catkin DESTINATION variables
# See http://ros.org/doc/api/catkin/html/adv_user_guide/variables.html
## Mark executable scripts (Python etc.) for installation
## in contrast to setup.py, you can choose the destination
# install(PROGRAMS
#   scripts/my_python_script
#   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
## Mark executables and/or libraries for installation
# install(TARGETS ${PROJECT_NAME} ${PROJECT_NAME}_node
#   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
## Mark cpp header files for installation
# install(DIRECTORY include/${PROJECT_NAME}/
#   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
#   FILES_MATCHING PATTERN "*.h"
#   PATTERN ".svn" EXCLUDE
## Mark other files for installation (e.g. launch and bag files, etc.)
# install(FILES
#   # myfile1
#   # myfile2
#   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
## Testing ##
## Add gtest based cpp test target and link libraries
# catkin_add_gtest(${PROJECT_NAME}-test test/test_sam_basic_orocos_rtt.cpp)
# if(TARGET ${PROJECT_NAME}-test)
#   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
# endif()
## Add folders to be run by python nosetests
# catkin_add_nosetests(test)
orocos_component(my_component src/basic_orocos_rtt.cpp)
set_property(TARGET my_component APPEND
        PROPERTY COMPILE_DEFINITIONS RTT_COMPONENT)
target_link_libraries(my_component
    ${USE_OROCOS_LIBRARIES}
    ${catkin_LIBRARIES}
# orocos_install_headers(DIRECTORY include/${PROJECT_NAME})
orocos_generate_package(INCLUDE_DIRS include)
Test:
deployer
Deployer [S]> loadComponent("my_component","MyComponent")
9.761 [ ERROR  ][loadComponent] Unable to create Orocos Component 'MyComponent': unknown component type.
 = false
Deployer [S]>
How to solve it?
Thank you~
Originally posted by sam on ROS Answers with karma: 2570 on 2017-08-16
I think u have to create a deployer script for that i.e to load a component in a deployer. u can either use lua, ops or xml script for that. in ops script it will be:
loadComponent("your_component_name", "actual_component")
here u can check which components can be loaded by typing displayComponents in taskbrowser i.e inside deployer. if u can't see the component which u want to load. than u have to first load the package which contains that component. For exampke if u have created that component inside a package named package_1 which may be ros package. Than u have to type:
import("package_1")
so that all the components which u have created inside this package will be avialabe in the taskborwser.
So all together:
  1. import("package_name")
  2. loadComponent("name_u_like", "component_name") thats all.
Originally posted by dinesh with karma: 932 on 2018-04-03
