Please help.
Very few times the gazebo opens with the loaded model, almost 99 times it fails with the below error.
After searching for one day in all forums I tried the following, so far no luck :(
- runnning verbose:=true
- running rosrun gzclient and then the launch file
- making sure box size is not zero in model description file
- transmission type properly mentioned in model description file
- gazebo ros control plugin installed and mentioned in model file
- gazebo ros control plugin installed (please note that i was able to run the same launch before, suddenly this error is coming up)
- checked namesapce
Launch file:
<?xml version="1.0" encoding="UTF-8"?>
<launch>
<arg name="world" default="empty"/>
<arg name="paused" default="false"/>
<arg name="use_sim_time" default="true"/>
<arg name="gui" default="true"/>
<arg name="headless" default="false"/>
<arg name="debug" default="false"/>
<arg name="x" default="0"/>
<arg name="y" default="0"/>
<arg name="x1" default="0"/>
<arg name="y1" default="0"/>
<arg name="z" default="0"/>
<arg name="roll" default="0"/>
<arg name="pitch" default="0"/>
<arg name="yaw" default="0"/>
<arg name="initial_pose_x" default="0"/>
<arg name="initial_pose_y" default="0"/>
<arg name="initial_pose_a" default="0.0"/>
<arg name="take_break" default="5.0"/>
<arg name="world_name" default="$(find robot_gazebo)/worlds/world_2.world" />
<arg name="ns_1" default="first_pelican" />
<include file="$(find gazebo_ros)/launch/empty_world.launch">
<arg name="world_name" value="$(arg world_name)"/>
<arg name="paused" value="$(arg paused)"/>
<arg name="use_sim_time" value="$(arg use_sim_time)"/>
<arg name="gui" value="$(arg gui)"/>
<arg name="headless" value="$(arg headless)"/>
<arg name="debug" value="$(arg debug)"/>
</include>
<group ns="$(arg ns_1)">
<param name="robot_description" command="$(find xacro)/xacro.py '$(find robot_description)/urdf/robot.xacro' namesapce_deploy:=$(arg ns_1)"/>
<node name="mybot_spawn" pkg="gazebo_ros" type="spawn_model" output="screen"
args="-urdf -param robot_description -model mybot_$(arg ns_1)
-x $(arg x) -y $(arg y) -z $(arg z)
-R $(arg roll) -P $(arg pitch) -Y $(arg yaw)" respawn="false" />
<!-- Load joint controller configurations from YAML file to parameter server -->
<rosparam file="$(find robot_gazebo)/config/robot_control.yaml" command="load"/>
<!-- load the controllers -->
<node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
output="screen" ns="/$(arg ns_1)" args="joint_state_controller joint1_position_controller"/>
<!-- convert joint states to TF transforms for rviz, etc -->
<node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher" respawn="false" output="screen">
<remap from="/joint_states" to="/$(arg ns_1)/joint_states" />
</node>
<!-- ************** Red circle image detection *************** -->
<node name="image_processing_node" pkg="image_processing" type="image_processing_node" output="screen">
<param name="namesapce_deploy" value="$(arg ns_1)"/>
</node>
<!-- ************** Navigation *************** -->
<node name="smart_exploration" type="smart_exploration" pkg="robot_exploration" output="screen">
<param name="dist_x" value="$(arg x)"/>
<param name="dist_y" value="$(arg y)"/>
</node>
</group>
</launch>
Trace:
balaji@balaji:~/Documents/balaji/unl/Media/Downloads/robot_ws_final$ source devel/setup.bash
balaji@balaji:~/Documents/balaji/unl/Media/Downloads/robot_ws_final$ roslaunch robot_gazebo robot_world.launch
... logging to /home/balaji/.ros/log/e78e4fbc-7f83-11e7-9f51-9801a7b07983/roslaunch-balaji-31825.log
Press Ctrl-C to interrupt
WARNING: disk usage in log directory [/home/balaji/.ros/log] is over 1GB.
It's recommended that you use the 'rosclean' command.
xacro: Traditional processing is deprecated. Switch to --inorder processing!
To check for compatibility of your document, use option --check-order.
For more infos, see http://wiki.ros.org/xacro#Processing_Order
started roslaunch server http://balaji:45487/
SUMMARY
PARAMETERS
* /first_pelican/image_processing_node/namesapce_deploy: first_pelican
* /first_pelican/joint1_position_controller/joint: palm_riser
* /first_pelican/joint1_position_controller/pid/d: 10.0
* /first_pelican/joint1_position_controller/pid/i: 0.01
* /first_pelican/joint1_position_controller/pid/p: 100.0
* /first_pelican/joint1_position_controller/type: effort_controller...
* /first_pelican/joint_state_controller/publish_rate: 100
* /first_pelican/joint_state_controller/type: joint_state_contr...
* /first_pelican/robot_description: <?xml version="1....
* /first_pelican/smart_exploration/dist_x: 0
* /first_pelican/smart_exploration/dist_y: 0
* /first_pelican/smart_exploration/namesapce_deploy: first_pelican
* /rosdistro: kinetic
* /rosversion: 1.12.7
* /use_sim_time: True
NODES
/first_pelican/
controller_spawner (controller_manager/spawner)
image_processing_node (image_processing/image_processing_node)
mybot_spawn (gazebo_ros/spawn_model)
robot_state_publisher (robot_state_publisher/robot_state_publisher)
smart_exploration (robot_exploration/smart_exploration)
gazebo (gazebo_ros/gzserver)
gazebo_gui (gazebo_ros/gzclient)
auto-starting new master
process[master]: started with pid [31839]
setting /run_id to e78e4fbc-7f83-11e7-9f51-9801a7b07983
process[rosout-1]: started with pid [31852]
started core service [/rosout]
process[gazebo-2]: started with pid [31864]
process[gazebo_gui-3]: started with pid [31879]
process[first_pelican/mybot_spawn-4]: started with pid [31886]
process[first_pelican/controller_spawner-5]: started with pid [31887]
process[first_pelican/robot_state_publisher-6]: started with pid [31888]
process[first_pelican/image_processing_node-7]: started with pid [31889]
process[first_pelican/smart_exploration-8]: started with pid [31890]
[ WARN] [1502559016.978709697]: The root link chassis has an inertia specified in the URDF, but KDL does not support a root link with an inertia. As a workaround, you can add an extra dummy link to your URDF.
[ INFO] [1502559016.986332012]: Got param: 0.000000
[ INFO] [1502559016.995995700]: Got param: 0.000000
[ INFO] [1502559016.999604731]: Got param: first_pelican
[ INFO] [1502559017.008884277]: In image_converter, got param: first_pelican
SpawnModel script started
[INFO] [1502559017.185603, 0.000000]: Loading model XML from ros parameter
[INFO] [1502559017.190666, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[ INFO] [1502559017.208092409]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1502559017.209366293]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[INFO] [1502559017.386893, 0.000000]: Controller Spawner: Waiting for service controller_manager/load_controller
[ INFO] [1502559017.566665686, 246.206000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1502559017.611486634, 246.249000000]: Physics dynamic reconfigure ready.
[INFO] [1502559017.795112, 246.428000]: Calling service /gazebo/spawn_urdf_model
[ INFO] [1502559018.103326226, 246.494000000]: Camera Plugin: Using the 'robotNamespace' param: '/first_pelican/'
[ INFO] [1502559018.107184854, 246.494000000]: Camera Plugin (ns = /first_pelican/) <tf_prefix_>, set to "/first_pelican"
[ INFO] [1502559018.628739638, 246.494000000]: Laser Plugin: Using the 'robotNamespace' param: '/first_pelican/'
[ INFO] [1502559018.628941833, 246.494000000]: Starting Laser Plugin (ns = /first_pelican/)
[ INFO] [1502559018.630496093, 246.494000000]: Laser Plugin (ns = /first_pelican/) <tf_prefix_>, set to "/first_pelican"
[INFO] [1502559018.650747, 246.494000]: Spawn status: SpawnModel: Successfully spawned entity
[ INFO] [1502559018.669444812, 246.494000000]: Loading gazebo_ros_control plugin
[ INFO] [1502559018.669578793, 246.494000000]: Starting gazebo_ros_control plugin in namespace: first_pelican
[ INFO] [1502559018.670483364, 246.494000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [/robot_description] on the ROS param server.
[WARN] [1502917332.970083, 246.277000]: Controller Spawner couldn't find the expected controller_manager ROS interface.
Model files in urdf folder:
- robot.xacro
This code block was moved to the following github gist: https://gist.github.com/answers-se-migration-openrobotics/576a987d7c64841a0bec25a3d68b41f4
robot.gazebo
$(arg namesapce_deploy) /robot_description $(arg namesapce_deploy) false true 10 left_wheel_hinge right_wheel_hinge 0.4 0.2 10 cmd_vel odom odom chassis Gazebo/Orange Gazebo/Blue Gazebo/Blue Gazebo/Green 30.0 1.3962634 800 800 R8G8B8 0.02 300 true 0.0 robot/camera1 image_raw camera_info camera 0.07 0.0 0.0 0.0 0.0 0.0 0 0 0 0 0 0 true 40 720 1 -1.570796 1.570796 0.10 30.0 0.01 gaussian 0.0 0.01 laser/scan hokuyo<xacro:arg name="namesapce_deploy" default="/" />
materials.xacro
After removing inertial element from root link in xacro, below are the new set of trance output:
... logging to /home/balaji/.ros/log/48e0f98c-82cb-11e7-80b7-0242aef01aad/roslaunch-balaji-13778.log
started roslaunch server http://balaji:39555/
SUMMARY
PARAMETERS
NODES
/first_pelican/
process[master]: started with pid [13792]
setting /run_id to 48e0f98c-82cb-11e7-80b7-0242aef01aad
process[rosout-1]: started with pid [13805]
process[gazebo-2]: started with pid [13819]
process[gazebo_gui-3]: started with pid [13832]
process[first_pelican/mybot_spawn-4]: started with pid [13839]
process[first_pelican/controller_spawner-5]: started with pid [13840]
process[first_pelican/robot_state_publisher-6]: started with pid [13841]
process[first_pelican/image_processing_node-7]: started with pid [13842]
process[first_pelican/smart_exploration-8]: started with pid [13843]
[ INFO] [1502919528.214139132]: Got param: 0.000000
[ INFO] [1502919528.241338494]: Got param: 0.000000
[ INFO] [1502919528.253249867]: Got param: first_pelican
[ INFO] [1502919528.277624421]: In image_converter, got param: first_pelican
[INFO] [1502919528.412530, 0.000000]: Loading model XML from ros parameter
File "/opt/ros/kinetic/lib/gazebo_ros/spawn_model", line 313, in <module>
sm.callSpawnService()
File "/opt/ros/kinetic/lib/gazebo_ros/spawn_model", line 239, in callSpawnService
model_xml = rospy.get_param(self.param_name)
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rospy/client.py", line 465, in get_param
return _param_server[param_name] #MasterProxy does all the magic for us
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rospy/msproxy.py", line 123, in __getitem__
raise KeyError(key)
KeyError: '/robot_description'
[ INFO] [1502919528.541984907]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1502919528.543089268]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[first_pelican/mybot_spawn-4] process has died [pid 13839, exit code 1, cmd /opt/ros/kinetic/lib/gazebo_ros/spawn_model -urdf -param /robot_description -model mybot_first_pelican -x 0 -y 0 -z 0 -R 0 -P 0 -Y 0 __name:=mybot_spawn __log:=/home/balaji/.ros/log/48e0f98c-82cb-11e7-80b7-0242aef01aad/first_pelican-mybot_spawn-4.log].
log file: /home/balaji/.ros/log/48e0f98c-82cb-11e7-80b7-0242aef01aad/first_pelican-mybot_spawn-4*.log
[INFO] [1502919528.635410, 0.000000]: Controller Spawner: Waiting for service controller_manager/load_controller
[ INFO] [1502919529.226806240, 246.207000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1502919529.284340544, 246.259000000]: Physics dynamic reconfigure ready.
Qt: Cannot set locale modifiers:
Originally posted by balajithevoyager on ROS Answers with karma: 50 on 2017-08-12
