I have installed, uninstalled, reinstalled the rqt packages using "sudo apt-get install ros-kinetic-rqt" i also did the same for the common-plugins. I keep getting the following:
nvidia@tegra-ubuntu:~$ rosrun rqt-graph rqt-graph [rospack] Error: package 'rqt-graph' not found
I tried running it in anew terminal as well... Still no luck. I am running this on a Jetson tx2. Any advice? Ive also tried the apt get update commands but theyre all up to date. Couldnt find much help looking through the other questions on rqt.
Just for my own eduification i looked in the file system /opt/ros/kinetic/share/rqt and the same for rqt-common-plugins. Both only contain a package.xml file.
also i do have a rqt-graph folder with a cmake folder, resource, package.xml and plugin.xml
EDIT: SO i reinstalled the full package. Same issue still occuring. Im not sure why im having this issue. Is it just that rqt is not compatible with the Nvidia Jetson?
Originally posted by cmacks on ROS Answers with karma: 1 on 2017-07-31
Comment by jayess on 2017-07-31:
How did you install ROS? Did you setup your environment properly?
Comment by cmacks on 2017-07-31:
I installed ros using the Jetson Hacks InstallRosTX2 package they made. I also did check that all of my files are in order. Ive run roswtf as well to check for any errors. I dont believe the normal ros install works on this board which is why they wrote a custom install script
Comment by aatzil on 2018-11-01:
Were you ever able to figure out how to get the rqt command to work properly while using a jetson tx2? I am having the same issue.
