Hey, I was trying to write a Python C++ wrapper as described in the Tutorial: "Using a C++ class in Python".
Now to my question, is there a way to compile the Module for Python 2.7 and 3 simultaneously using catkin? So i can import the wrapper Class in both versions?
Because currently when Importing the wrapper to python 3 this error is thrown: ImportError: dynamic module does not define module export function (PyInit__wrapper_cpp) Since i can only link it against the python 2 libs.
Under Python 2 it is currently working without any errors.
Thanks for your help, Thomas
Originally posted by Thomas_Blo on ROS Answers with karma: 11 on 2017-07-28
It's doable, but pretty disgusting (macros/pragmas are very involved, due to major difference in the wrapper API). I wouldn't bother with the python 2/3 backwards compatibility, just stick with 3 if you wrote it in 3. Mixing python versions in ROS gets messy very quickly.
Originally posted by allenh1 with karma: 3055 on 2017-07-30
