When running commands for Rviz I am not getting any output on the terminal and Rviz gui is not loading. I am running Indigo.
Originally posted by tyberious on ROS Answers with karma: 1 on 2017-07-20
Comment by jayess on 2017-07-20:
Are you running roscore?
Comment by tyberious on 2017-07-20:
I am running roscore.
:~$ rosrun rviz rviz
Run rosrun rqt_logger_level rqt_logger_level and play around with the different loggers and logger levels for rviz and see if that tells you anything.
Hey Jayess I am not seeing rviz listed when running rosrun rqt_logger_level rqt_logger_level
The node name should be something along the lines of /rviz_1500579339612988311.
How did you install ROS?
sudo apt install ros-indigo-desktop-full I dont have anything that looks like that /rviz_1500579339612988311
And nothing gets output to the terminal when you run rosrun rviz rviz?
Comment by gvdhoorn on 2017-07-21:
As with all RViz questions: please tell us whether you're running Linux/ROS in a VM, which OS this is, whether you have drivers installed for your 3D hardware, etc, etc.
Please update your original question. Comments are not meant for that.
If running apt install is all you did to install ROS and you haven't setup your environment things won't likely work right. Have you followed the installation tutorial?
Originally posted by Airuno2L with karma: 3460 on 2017-07-21
