I am trying to create 2d Occupancy grid from zed stereo camera .I referred this tutorial http://wiki.ros.org/rtabmap_ros/Tutorials/StereoOutdoorMapping for doing so.But I am unable recreate it since here its given from bumblebee2 stereo camera to OGM.Also it subscribe to these topics: 1]/stereo_camera/left/image_raw_throttle/compressed 2]/stereo_camera/right/image_raw_throttle/compressed 3]/stereo_camera/left/camera_info_throttle 4]/stereo_camera/right/camera_info_throttle 5]/tf
which i dont know how to publish or record using bag file from standalone stereo camera. Please suggest me how to implement this or any other way to implement the problem statement.I request you guys to give detailed procedure since I am novice to ROS and robotics
Thanks in advance
Originally posted by ankursingh0820 on ROS Answers with karma: 11 on 2017-07-18
Hi
I think basically you are asking you need to publish the same topics from ZED as it is being published by Bumbelbee2? If yes
You need to install the ZED ros package as mentioned in the below link.
http://wiki.ros.org/zed-ros-wrapper
Once you do it you need to launch the ZED camera launch file by this command roslaunch zed_wrapper zed.launch
After this launch the following topics will be published :
/zed/confidence/confidence_image
/zed/confidence/confidence_image/compressed
/zed/confidence/confidence_image/compressed/parameter_descriptions
/zed/confidence/confidence_image/compressed/parameter_updates
/zed/confidence/confidence_image/compressedDepth
/zed/confidence/confidence_image/compressedDepth/parameter_descriptions
/zed/confidence/confidence_image/compressedDepth/parameter_updates
/zed/confidence/confidence_image/theora
/zed/confidence/confidence_image/theora/parameter_descriptions
/zed/confidence/confidence_image/theora/parameter_updates
/zed/confidence/confidence_map
/zed/depth/camera_info
/zed/depth/depth_registered
/zed/depth/depth_registered/compressed
/zed/depth/depth_registered/compressed/parameter_descriptions
/zed/depth/depth_registered/compressed/parameter_updates
/zed/depth/depth_registered/compressedDepth
/zed/depth/depth_registered/compressedDepth/parameter_descriptions
/zed/depth/depth_registered/compressedDepth/parameter_updates
/zed/depth/depth_registered/theora
/zed/depth/depth_registered/theora/parameter_descriptions
/zed/depth/depth_registered/theora/parameter_updates
/zed/disparity/disparity_image
/zed/joint_states
/zed/left/camera_info
/zed/left/camera_info_raw
/zed/left/image_raw_color
/zed/left/image_raw_color/compressed
/zed/left/image_raw_color/compressed/parameter_descriptions
/zed/left/image_raw_color/compressed/parameter_updates
/zed/left/image_raw_color/compressedDepth
/zed/left/image_raw_color/compressedDepth/parameter_descriptions
/zed/left/image_raw_color/compressedDepth/parameter_updates
/zed/left/image_raw_color/theora
/zed/left/image_raw_color/theora/parameter_descriptions
/zed/left/image_raw_color/theora/parameter_updates
/zed/left/image_rect_color
/zed/left/image_rect_color/compressed
/zed/left/image_rect_color/compressed/parameter_descriptions
/zed/left/image_rect_color/compressed/parameter_updates
/zed/left/image_rect_color/compressedDepth
/zed/left/image_rect_color/compressedDepth/parameter_descriptions
/zed/left/image_rect_color/compressedDepth/parameter_updates
/zed/left/image_rect_color/theora
/zed/left/image_rect_color/theora/parameter_descriptions
/zed/left/image_rect_color/theora/parameter_updates
/zed/map
/zed/odom
/zed/point_cloud/cloud_registered
/zed/rgb/camera_info
/zed/rgb/camera_info_raw
/zed/rgb/image_raw_color
/zed/rgb/image_raw_color/compressed
/zed/rgb/image_raw_color/compressed/parameter_descriptions
/zed/rgb/image_raw_color/compressed/parameter_updates
/zed/rgb/image_raw_color/compressedDepth
/zed/rgb/image_raw_color/compressedDepth/parameter_descriptions
/zed/rgb/image_raw_color/compressedDepth/parameter_updates
/zed/rgb/image_raw_color/theora
/zed/rgb/image_raw_color/theora/parameter_descriptions
/zed/rgb/image_raw_color/theora/parameter_updates
/zed/rgb/image_rect_color
/zed/rgb/image_rect_color/compressed
/zed/rgb/image_rect_color/compressed/parameter_descriptions
/zed/rgb/image_rect_color/compressed/parameter_updates
/zed/rgb/image_rect_color/compressedDepth
/zed/rgb/image_rect_color/compressedDepth/parameter_descriptions
/zed/rgb/image_rect_color/compressedDepth/parameter_updates
/zed/rgb/image_rect_color/theora
/zed/rgb/image_rect_color/theora/parameter_descriptions
/zed/rgb/image_rect_color/theora/parameter_updates
/zed/right/camera_info
/zed/right/camera_info_raw
/zed/right/image_raw_color
/zed/right/image_raw_color/compressed
/zed/right/image_raw_color/compressed/parameter_descriptions
/zed/right/image_raw_color/compressed/parameter_updates
/zed/right/image_raw_color/compressedDepth
/zed/right/image_raw_color/compressedDepth/parameter_descriptions
/zed/right/image_raw_color/compressedDepth/parameter_updates
/zed/right/image_raw_color/theora
/zed/right/image_raw_color/theora/parameter_descriptions
/zed/right/image_raw_color/theora/parameter_updates
/zed/right/image_rect_color
/zed/right/image_rect_color/compressed
/zed/right/image_rect_color/compressed/parameter_descriptions
/zed/right/image_rect_color/compressed/parameter_updates
/zed/right/image_rect_color/compressedDepth
/zed/right/image_rect_color/compressedDepth/parameter_descriptions
/zed/right/image_rect_color/compressedDepth/parameter_updates
/zed/right/image_rect_color/theora
/zed/right/image_rect_color/theora/parameter_descriptions
/zed/right/image_rect_color/theora/parameter_updates
/zed/zed_wrapper_node/parameter_descriptions
/zed/zed_wrapper_node/parameter_updates
From this list you can easily get the topics you are looking for. One you figure that out you can modify the subscriber in the Grid Map package to subscribe the new topics. I think after this you will be good to go...
All the best!!!!
Regards, Saptarshi
Originally posted by Robot with karma: 180 on 2018-07-20
Comment by Robot on 2018-07-20:
Please don't forget to upvote if this works and feel free to ask anything more specific to this......
