Hello all,
I'm trying to fuse an IMU and a DVL (measures linear velocity on x, y, z). I have the following axis configurations.
  • base_link : robot's frame
  • base_imu : imu's frame
  • base_dvl : DVL's frame
I have a transform broadcaster which broadcasts base_imu->base_link and base_dvl->base_link. The picture attached shows the frame poses. I have set the fixed frame as base_link here (rviz). image description
This is the TF tree:
image description
But when I run robot_localization, the localization is perfect but it doesn't show my sensor frames. There are also some warnings generated in rviz (check left pane), saying there isn't any transform to odom frame. But there is a transform as per the tf_tree. Here is a picture: image description
How do I fix this issue?
Originally posted by lffox on ROS Answers with karma: 7 on 2017-07-14
Comment by Humpelstilzchen on 2017-07-16:
The timestamp on the different transforms look ways too off for me.They should happen nearly at the same time. Do you run ros across different computers? If so check the current date and time both.
Comment by lffox on 2017-07-18:
Hi, Thanks for your reply. The timings don't matter to me much since they are just static transforms. But can that be cause for this issue?
Comment by Humpelstilzchen on 2017-07-22:
The ROS nodes do not know that the transforms do not change. When they are outdated they are ignored.
You are using a static transform publisher, but you appear to be using the static transform publisher from tf, and not tf2_ros. Is that correct? The time stamps are going to matter in this case, and it appears that they are almost 5 days apart. I'd switch to the static transform publisher in tf2_ros.
If you already are, I'd give some more details about your setup, including posting the launch files. Is all of this running on the same machine?
Originally posted by Tom Moore with karma: 13689 on 2017-09-28
