https://youtu.be/vQJC-mlnRKY
In the video I move the robot, and the laser readings seem to move along with the robot, when in fact they should be more stationary. I then increase the delay on the /scan topic, and I get a really thick wall, in the direction in which the robot is moving.
Any idea what might cause it? It seems that algorithms like gmapping are producing a pretty decent map.
I did a tf view_frame, and the tf's are all publishing at about 5hz, the robot is defined in a urdf.
Thank you in advance!
Here is the tf_view file, the laser scan comes from veldyne: C:\fakepath\frames.png
Originally posted by Cristian11235 on ROS Answers with karma: 55 on 2017-07-14
Comment by allenh1 on 2017-07-14:
Could you post the view_frames.py output?
Comment by Cristian11235 on 2017-07-14:
Ive updated the original post with the view frames output
It looks like your odometry is scaled incorrectly; notice how the laser scans move, but only about half as far as the robot moves.
Originally posted by ahendrix with karma: 47576 on 2017-07-14
The issue was indeed the odometry was scaled exactly how you said, by half of what the robot moves at.
I had changed the motor controlled/ encoders and did not update the code to properly reflect this.
Thank you
