Hi
I just installed ros kinetic, gazebo and turtlebot in Ubuntu 16.04. when i run
roslaunch turtlebot_gazebo turtlebot_world.launch
in terminal gazebo opens with the standard obstacles but there is no bot.
I installed gazebo with apt-get.
this is the error i get i terminal:
[spawn_turtlebot_model-4] process has died [pid 11263, exit code 1, cmd /opt/ros/kinetic/lib/gazebo_ros/spawn_model -unpause -urdf -param robot_description -model mobile_base __name:=spawn_turtlebot_model __log:=/home/andreas/.ros/log/d859e7e6-659c-11e7-bff4-a402b924af68/spawn_turtlebot_model-4.log].
log file: /home/andreas/.ros/log/d859e7e6-659c-11e7-bff4-a402b924af68/spawn_turtlebot_model-4*.log
Any help appreciated!
Edit: This is what terminal is showing when i run roslaunch turtlebot3_gazebo turtlebot3_empty_world.launch.
Still no bot showing:
andreas@andreas-N501VW:~$ roslaunch turtlebot3_gazebo turtlebot3_empty_world.launch
... logging to /home/andreas/.ros/log/10d4ccd2-6677-11e7-bff4-a402b924af68/roslaunch-andreas-N501VW-30220.log
Press Ctrl-C to interrupt
xacro: Traditional processing is deprecated. Switch to --inorder processing!
To check for compatibility of your document, use option --check-order.
For more infos, see http://wiki.ros.org/xacro#Processing_Order
deprecated: xacro tags should be prepended with 'xacro' xml namespace.
Use the following script to fix incorrect usage:
        find . -iname "*.xacro" | xargs sed -i 's#<\([/]\?\)\(if\|unless\|include\|arg\|property\|macro\|insert_block\)#<\1xacro:\2#g'
when processing file: /opt/ros/kinetic/share/turtlebot3_description/urdf/turtlebot3_burger.urdf.xacro
xacro.py is deprecated; please use xacro instead
started roslaunch server http://andreas-N501VW:35697/
SUMMARY
PARAMETERS
 * /robot_description: <?xml version="1....
 * /rosdistro: kinetic
 * /rosversion: 1.12.7
 * /use_sim_time: True
NODES
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
    spawn_urdf (gazebo_ros/spawn_model)
core service [/rosout] found
process[gazebo-1]: started with pid [30242]
process[gazebo_gui-2]: started with pid [30247]
process[spawn_urdf-3]: started with pid [30252]
  File "/opt/ros/kinetic/lib/gazebo_ros/spawn_model", line 32, in <module>
    import tf.transformations as tft
  File "/opt/ros/kinetic/lib/python2.7/dist-packages/tf/__init__.py", line 28, in <module>
    from _tf import *
ImportError: /home/andreas/anaconda2/bin/../lib/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/ros/kinetic/lib/python2.7/dist-packages/tf/_tf.so)
[ INFO] [1499808994.861676790]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1499808994.862201127]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[spawn_urdf-3] process has died [pid 30252, exit code 1, cmd /opt/ros/kinetic/lib/gazebo_ros/spawn_model -urdf -model turtlebot3_burger -x 0.0 -y 0.0 -z 0.0 -param robot_description __name:=spawn_urdf __log:=/home/andreas/.ros/log/10d4ccd2-6677-11e7-bff4-a402b924af68/spawn_urdf-3.log].
log file: /home/andreas/.ros/log/10d4ccd2-6677-11e7-bff4-a402b924af68/spawn_urdf-3*.log
[ INFO] [1499808995.548652766, 0.023000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1499808995.631034578, 0.102000000]: Physics dynamic reconfigure ready.
Originally posted by AndreasG on ROS Answers with karma: 16 on 2017-07-10
Comment by tfoote on 2017-07-10:
Please provide more information on how to reproduce your problem. As well as the full console logs of what you're doing, not just the one line error. http://wiki.ros.org/Support
Comment by AndreasG on 2017-07-11:
The problem is that i dont find a bot when i run "roslaunch turtlebot_gazebo turtlebot_world.launch" in terminal. Gazebo opens and there are objects like cylinder, jersy barrier, bookshelf an so on showing in the map/world. This happens everytime I run the command. Is it not supposed to show up?
And where do I find that log?
Comment by gvdhoorn on 2017-07-12:
@AndreasG: please don't pose answers unless you are answering your own question. For everything else, either use comments (to interact with posters of specific answers) or update your original question text. Use the edit button/link for that.
Thanks.
I found a solution. There was a problem with having Anaconda2 installed. Since I dont need Anaconda I deleted it along with the content of catkin_ws. I ran the installation steps again and it worked.
Originally posted by AndreasG with karma: 16 on 2017-07-18
