Hello everyone,
I am currently trying to connect my arduino due to my pc in order to run my ROS package I wrote, which shall communicate with the arduino.
I can compile and upload my program via the GUI. To start the serial connection, I run:
rosrun rosserial_python serial_node.py /dev/ttyACM0
Which produces the output:
[INFO] [1499369503.299387]: ROS Serial Python Node
[INFO] [1499369503.305172]: Connecting to /dev/ttyACM0 at 57600 baud
[ERROR] [1499369520.430946]: Unable to sync with device; possible link problem or link software version mismatch such as hydro rosserial_python with groovy Arduino
I don't really understand the message. I wrote all my nodes in ROS kinetic and also installed rosserial via:
sudo apt-get install ros-kinetic-rosserial-arduino
just like it was done in the tutorial.
Why is the arduino assigned to a particular ROS version anyway? How can I set this to kinetic?
I am working on a virtual box with Ubuntu 16.04
Does somebody know how to solve that problem?
Thanks in advance,
Felix
Originally posted by Felix_N on ROS Answers with karma: 115 on 2017-07-06
Comment by gvdhoorn on 2017-07-06:\
this is an example. It does not refer to exact versions of anything. It's basically giving you one specific example of a cause for this issue (ie: using different versions of things).
Comment by Felix_N on 2017-07-06:
I know. But still i have no idea how to solve this.
It now works on an Arduino Mega 2650. Same settings, same code, works.
It even got the same amount of pins available.
Originally posted by Felix_N with karma: 115 on 2017-07-09
