I am trying to use cv_bridge to convert an image from /disp_map/image (32FC1 encoding according to msg->encoding ) to an image usable in opencv with the following code :
void detectionCallback(const sensor_msgs::ImageConstPtr& msg) {
   cv_bridge::CvImagePtr cv_ptr;
   try
     cv_ptr = cv_bridge::toCvCopy(msg, "mono8");
    catch (cv_bridge::Exception& e)
    ROS_ERROR("cv_bridge exception: %s", e.what());
    return;
And i get the following error :
[ERROR] [1499238883.621456903]: cv_bridge exception: [32FC1] is not a color format. but [mono8] is. The conversion does not make sense
What's the best solution to solve this ?
Originally posted by jeanpolochon on ROS Answers with karma: 140 on 2017-07-05
I manage to make it works using opencv 3 (compiling cv_bridge from sources )
I had to add a few lines of code to convert the image format. This solution is not very efficient but it works. If somebody has a better solution that would be nice !
The code I used :
  cv_bridge::CvImageConstPtr cv_ptr;
  try
    cv_ptr = cv_bridge::toCvShare(msg);
    return;
  Mat mono8_img = cv::Mat(cv_ptr->image.size(), CV_8UC1);
  cv::convertScaleAbs(cv_ptr->image, mono8_img, 100, 0.0);
Originally posted by jeanpolochon with karma: 140 on 2017-07-05
See if some of the other answers to very similar questions are of any help
http://answers.ros.org/question/60182/error-unable-to-convert-32fc1-image-to-bgr8-while-extracting-rbgd-data-from-a-bag/
http://answers.ros.org/question/199642/is-it-possible-to-convert-depth-messages-as-ipl-image-using-cvbridge/
http://answers.ros.org/question/212747/cvbridge-conversion-problem-asus-xtion-depth-image-to-opencv/
