i went to ~/catkin_ws(my workspace) and then to src folder and created my package with the command
catkin_create_pkg face sensor_msgs opencv2 cv_bridge rospy std_msgs
The package was successfully created.Then i went to catkin_ws and executed the command
catkin_make
it showed an error
CMake Error at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package): Could not find a package configuration file provided by "opencv2" with any of the following names:
opencv2Config.cmake
opencv2-config.cmake
Add the installation prefix of "opencv2" to CMAKE_PREFIX_PATH or set "opencv2_DIR" to a directory containing one of the above files. If "opencv2" provides a separate development package or SDK, be sure it has been installed. Call Stack (most recent call first): face/CMakeLists.txt:10 (find_package)
-- Configuring incomplete, errors occurred! See also "/home/hari/catkin_ws/build/CMakeFiles/CMakeOutput.log". See also "/home/hari/catkin_ws/build/CMakeFiles/CMakeError.log". Makefile:738: recipe for target 'cmake_check_build_system' failed make: *** [cmake_check_build_system] Error 1 Invoking "make cmake_check_build_system" failed
Originally posted by HHG on ROS Answers with karma: 1 on 2017-06-28
Well, it could not detect OpenCV2 package in ROS Kinetic version because kinetic has an OpenCV3 package in their Debain package as default.
First of all, you need to install (if you haven't install opencv before)
sudo apt-get install ros-kinetic-opencv3
Secondly, change the dependency to opencv3 from opencv2 in that concerned package and then catkin_make.
Hope it helps!
Originally posted by vignesh with karma: 101 on 2017-06-30
