Hello,
I am new to ROS and Linux, I am following tutorial on ROS installation, when i run the rospack find roscpp I get the following respond [rospack] Error: package 'roscpp' not found not sure why?
Originally posted by UaeZombie on ROS Answers with karma: 1 on 2017-06-17
Make sure, when following the install tutorial, you executed the command
echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc
This sets up your shell to always add the correct ROS variables to the Linux environment. You should then be able to use rospack find roscpp correctly. If not, check the output of printenv | grep ROS includes the lines:
ROS_ROOT=/opt/ros/kinetic/share/ros
ROS_PACKAGE_PATH=/opt/ros/kinetic/share
If the output is correct, but rospack find isn't working, we have another problem.
Originally posted by ufr3c_tjc with karma: 885 on 2017-06-18
Comment by UaeZombie on 2017-06-19:
ROS_PACKAGE_PATH=/home/uaefame/fuerte_workspace/sandbox still not working
Comment by ufr3c_tjc on 2017-06-19:
What version of Linux do you have? Fuerte is 5 years old now and I highly recommend installing something more recent. Preferably Kinetic, but Indigo at least.
Anyway, your ROS_PACKAGE_PATH doesn't contain the path to the actual ros install. Type echo "source /opt/ros/fuerte/setup.bash" >> ~/.bashrc and restart your terminal.
