Hi everyone,
I'm working on arm robotic, first, i wrote a physical model of the arm with a URDF files. This model work with Rviz and Gazebo. Moreover, i created a controllers.yaml file (for controls all robot's joints) and when I use the command : rostopic pub /arm_controller/command trajectory_msgs/JointTrajectory '{joint_names: ["hip","shoulder","elbow","wrist"], points: [{positions:[0.1,-0.5,0.5,0.75], time_from_start: [1.0,0.0]}]}' -1
both models (on rivz and gazebo) move simultaneously.
But now, I want to create a .cpp file for the arm to move independently by using trajectory_msgs::JointTrajectory. Here's my cpp file :
#include <ros/ros.h>
#include <trajectory_msgs/JointTrajectory.h>
ros::Publisher arm_pub;
int main(int argc, char** argv) {
ros::init(argc, argv, "state_publisher");
ros::NodeHandle n;
arm_pub = n.advertise<trajectory_msgs::JointTrajectory>("/arm_controller/command",1);
trajectory_msgs::JointTrajectory traj;
traj.header.stamp = ros::Time::now();
traj.header.frame_id = "base_link";
traj.joint_names.resize(4);
traj.points.resize(4);
traj.joint_names[0] ="hip";
traj.joint_names[1] ="shoulder";
traj.joint_names[2] ="elbow";
traj.joint_names[3] ="wrist";
while(ros::ok()){
for(int i=0;i<4;i++) {
int j = i%3;
trajectory_msgs::JointTrajectoryPoint points_n;
points_n.positions.push_back(j+0.1);
points_n.positions.push_back(j+0.3);
points_n.positions.push_back(j);
traj.points.push_back(points_n);
traj.points[i].time_from_start = ros::Duration(1.0,0.0);
arm_pub.publish(traj);
ros::spinOnce();
return 0;
When i launch my file.launch and I rosrun my cpp file, both are connected on rqt_graph. But immediately, i have an error (on launch terminal) :
[ERROR] [1497596211.214814221, 9.889000000]: Trajectory message contains waypoints that are not strictly increasing in time.
Effectively, when i use the command rostopic echo /arm_controller/command
, i have :
`positions: [0.0, 1.0, 0.0, 2.0]
velocities: []
accelerations: []
effort: []
time_from_start:
secs: 0
nsecs: 0`
The time_from_start is always 0. So, I think i've a problem in my code but i don't know where.
Does anyone have an idea what is wrong? Thank you.
Originally posted by w.fradin on ROS Answers with karma: 38 on 2017-06-16
Comment by gvdhoorn on 2017-06-16:
Not a complete answer, but: know that time_from_start
does not encode segment length directly, but is actually the point in time at which that TrajectoryPoint
should be executed. Setting them all to 1.0
is not going to work, as all traj pts will then effectively 'overlap' in time.
Comment by w.fradin on 2017-06-16:
I understood that each trajectory point's time_from_start must be greater than the last. But I tried to increase this time but i have the same error. The problem is only in my code or it could come from my launch files?
Comment by gvdhoorn on 2017-06-17:
As I wrote, it was just a comment, not an answer to your problem. I just wanted to make you aware that your example code seems to be setting time_from_start
to incorrect values.
