/ur_driver/jointspeed
is not a publication, but a subscription.
You're supposed to send it joint velocities, they will not be published there.
Edit:
Maybe there are some mistakes in my expression ,I use rostopic echo
just want to see whether it has changed after publishing.I attempted to see its message details by using TAB key.I found that it is similar to /Follow_Joint_Trajectory.That make me confused,why I need to set joint position again
The fact that it uses a JointTrajectory
msg doesn't mean that you have to set position
. See RosWrapper::speedInterface(..). It only uses the velocity
field.
This is also described in the readme (emphasis mine):
joint_speed
: Takes messages of type trajectory_msgs/JointTrajectory
. Parses the first JointTracetoryPoint and sends the specified joint speeds and accelerations to the robot.
Originally posted by gvdhoorn with karma: 86574 on 2017-06-08
Comment by bobpop on 2017-06-08:
Eh,which topic or command I should use?If I use the /ur_driver/FollowJointTrajectory
,that means I must set joint position,velosity… I learned that it's a position control and position perhaps is not the most important value in my consideration , what I want to just move in a direction.
Comment by gvdhoorn on 2017-06-08:
I'm a bit confused by your comment. The topic is fine, rostopic echo ..
just won't do anything with it as there are no message published to it. You have to publish messages to it.
Comment by bobpop on 2017-06-09:
oh,I got it.Thanks,gvdhoorn.By the way,I should use trajectory_msgs::JointTrajectory
directly instead of control_msgs::FollowJointTrajectoryAction>::Goal
,it's right?
