Hello everybody. I'm trying to read barcodes using cv_camera and zbar_ros. Below you can read what I am doing.
$ rosrun cv_camera cv_camera_node /cv_camera/image_raw:=image
</pre>
<pre>[ INFO] [1496521778.337223498]: using default calibration URL
[ INFO] [1496521778.337350789]: camera calibration URL: file:///home/wojtas/.ros/camera_info/camera.yaml
[ INFO] [1496521778.337442923]: Unable to open camera calibration file [/home/wojtas/.ros/camera_info/camera.yaml]
[ WARN] [1496521778.337476985]: Camera calibration file /home/wojtas/.ros/camera_info/camera.yaml not found.
</pre>
<pre>
$ rosrun zbar_ros barcode_reader_node
[ INFO] [1496521948.392267314]: Initializing nodelet with 4 worker threads.
After trying reading barcode from my bottle of beer :) I get
$ rostopic echo /barcode
</pre>
<pre>data: 4321136100317
data: 7611166100317
data: 7225226100317
data: 8639213100317
data: 8342113100317
</pre>
When I'm using zbarcam application and reading the same barcode I get
<pre>
$ zbarcam
EAN-13:5900699100317
So I'm very confused. Why barcodes from /barcode topic are different from original barcode? Any ideas?
Additional info:
$ roscore
ros_comm version 1.12.7
SUMMARY
PARAMETERS
 * /rosdistro: kinetic
 * /rosversion: 1.12.7
$ rostopic list
/barcode
/camera_info
/image
/image/compressed
/image/compressed/parameter_descriptions
/image/compressed/parameter_updates
/image/compressedDepth
/image/compressedDepth/parameter_descriptions
/image/compressedDepth/parameter_updates
/image/theora
/image/theora/parameter_descriptions
/image/theora/parameter_updates
/rosout
/rosout_agg
Originally posted by wojtas on ROS Answers with karma: 36 on 2017-06-03
Comment by ahendrix on 2017-06-04:
I don't anything about zbar, but my first debugging step would be to try to capture an image through ROS as a PNG and then run both the ROS and non-ROS versions of zbar on it; to figure out if the difference is on the image capture side or in the zbar_ros node.
The image_saver and image_publisher nodes will probably be helpful.
Comment by wojtas on 2017-06-05:
Thank you ahendrix.
Dirty reads aren't connected neither with zbar_ros nor with cv_camera. I've played with zbarcam little longer and it showed me that dirty reads happens.
So I think the "problem" is connected with zbar library. This library is not as reliable as I thought :(.
Originally posted by wojtas with karma: 36 on 2017-06-05
