We are working on a project to explore the possibilities of ROS Industrial for SME companies. However, the ROS Industrial website (rosindustrial.org) is very often not reachable and this is not beneficial for the confidence of companies in the technology. Is it possible to host the ROS Industrial website at a more reliable provider?
I have not experienced problems with the ros.org website.
Originally posted by Wilco Bonestroo on ROS Answers with karma: 159 on 2017-05-31
The rosindustrial.org site is hosted on square space which has very little downtime:
http://www.webhostingstuff.com/uptime/SquareSpace.html
This may be a regional issue. We are currently looking into this, so if you could post some more data, that would be helpful.
Thank you, -Austin
Originally posted by aderic with karma: 31 on 2017-05-31
Thank you for the information. Indeed, this is an issue within our organisation. The IP address of rosindustrial.org is blocked by our firewall because the website andyschwinn.com (which doesn't exist anymore) had the same IP address as rosindustrial.org and is reported as a source of cryptolocker malware. Our system administrator has manually removed the block. However, I expect that more organisations will have the same issue.
Originally posted by Wilco Bonestroo with karma: 159 on 2017-06-01
Comment by gvdhoorn on 2017-06-01:
Could I please ask you to not post answers, unless you are answering your own question? ROS Answers is not a regular forum, but a Q&A site. Discussion is best done in comments.
Thanks.
