Hello~ I'm new in ROS and am learning it by the tutorials.However,there were some errors when I followed the Tutorial: Using a URDF in Gazebo. Everthing is normal until I ran the the command:
roslaunch rrbot_gazebo rrbot_world.launch
image description
However, it seems I can start gazebo by command line. image description
I have tried sudo apt-get install --reinstall ros-indigo-gazebo-ros,but it didn't work.
This is all the files I have in /opt/ros/indigo/lib/gazebo_ros/.Is there anything wrong?
image description
Thanks a lot for your help!
Originally posted by Richardaria on ROS Answers with karma: 21 on 2017-05-31
Comment by jarvisschultz on 2017-05-31:
How did you install gazebo_ros -- from source or from apt-get? What does rospack find gazebo_ros return?
Comment by Richardaria on 2017-05-31:
It returns this: /opt/ros/indigo/share/gazebo_ros
Should I reinstall Gazebo?
You could certainly try sudo apt-get install --reinstall ros-indigo-gazebo-ros although, that wouldn't explain what went wrong in the first place. Do you have the missing executables in /opt/ros/indigo/lib/gazebo_ros/ (that's where they should get installed)?
I tried sudo apt-get install --reinstall ros-indigo-gazebo-ros .However,the same problem still exist. I have attached a screenshot of all the files I got in /opt/ros/indigo/lib/ga zebo_ros/. Is there any problem? Thanks for your help!
Comment by jarvisschultz on 2017-06-01:
If that works, then there is likely something wrong with your workspace. Try deleting the build/ and devel/ directories and then re-running catkin_make
Also, as a side note, please stop posting images to show information that is fundamentally text (list files in a directory, error messages, terminal commands, etc.). Images are not searchable nor are they copy/paste-able. Please post this type of thing using the preformatted text button.
Comment by Richardaria on 2017-06-01:
It works just as you said.Thanks a lot. It seems that I have installed gazebo twice.I'm not very familiar with the editor of this website, learning and improving. Thanks for you advice.
Comment by jarvisschultz on 2017-06-02:
Is your original question resolved? Can you now run your rrobt launch file?
3 Answers 3
Do you maybe have an additional copy of gazebo_ros in your workspace? Try using rosrun to manually start one of the missing nodes: (i) start roscore (ii) source /opt/ros/indigo/setup.bash to use just the base install (deactivates your workspace) (iii) rosrun gazebo_ros gzserver
Originally posted by jarvisschultz with karma: 9031 on 2017-06-01
I solved this issue by these steps:
  1. delete build and devel folders.
  2. catkin_make.
Originally posted by lyz with karma: 11 on 2019-01-28
This worked for me:-
sudo chmod +x /file path*(gzserver)
sudo chmod +x /file path*(gzclient)
sudo chmod +x /file path*(spawn_model)
*means location where the files are present
for eg:/home/tom/project_ws/src/gazebo_ros/gazebo_ros/scripts/gzclient
Comment by Jeremy_Liu on 2022-04-11:
This works for me, too. Thanks!
Comment by Hector P on 2023-01-19:
This works for me, too. Ty!
