Hi all, I am following the beginner rosnode tutorial http://wiki.ros.org/ROS/Tutorials/UnderstandingNodes I have installed ros in bash. When I enter command "rosrun turtlesim turtlesim_node" after running "roscore", I get the following error:
QXcbConnection: Could not connect to display :0.0
Aborted (core dumped)
Are there any solutions to this? Thanks
Originally posted by Isam Abdullah on ROS Answers with karma: 3 on 2017-05-25
Comment by kathrin@ros on 2018-05-23:
Hi,
I'm a beginner in Ros and just started the tutorial too.Moreover I'm working on SLAM methods with ROS. Maybe ur still interested in this topic and would like to discuss with me about it.
Comment by Isam Abdullah on 2018-05-23:
Yeah sure. I would be happy to help/discuss.
I'm a total beginner. But did you manage this connection problem?
Are you installing ros in windows bash? If so, then it is not supported and you have to do alot of hacks to make it work on that.
So it is advisable for a beginner to work in ubuntu.
Yes, I did. I managed it with Xserver, seems to be stable.It seems more complicated to me to change to ubuntu...
Great!... btw are you university/college graduate?
Did you installed ubuntu additionally to windows?Does it work well parallel?
Yes... It works well to have dual boot. Windows and ubuntu side by side.
I am an electroengineering student, trying to advance in my bachelor thesis(just began).And you?
Well, I have graduated from my BS computer science previous year. I have been working in a startup related to computer vision and deep learning since the past year.
Sounds great. I've tried to run ubuntu on/as a live stick. But I didn't know how to access ros,not knowing where it is located on the hard disk or haven't set any path variable. How did you run ubuntu and how to get access to the ros without downloading it again?
Thanks in advance.
