Is it safe to give 5v through 5v pin of arduino uno r3 while the USB cable is inserted? I have ESCs connected to it which aren't likely to start in other cases. The 5v and gnd is coming from the BEC circuit of a connected ESC. Please help me. Thanksenter image description here
6
  • $\begingroup$ yes i supply 5v from esc to arduino $\endgroup$
    – Bilal Ayub
    Sep 18, 2015 at 18:58
  • $\begingroup$ Cause i am making quadcopter so escs are used which provide 5v output. $\endgroup$
    – Bilal Ayub
    Sep 18, 2015 at 19:00
  • $\begingroup$ any problem can happen with that? $\endgroup$
    – Bilal Ayub
    Sep 18, 2015 at 19:01
    $\begingroup$ Chuck, Bilal isn't talking about the ESC's PWM output (its motor drive), but about a 5V Aux Out on the ESC, or a 5V BEC (battery eliminator circuit) on the ESC. The comments in your answer about not connecting to an ESC may be irrelevant. $\endgroup$ Sep 19, 2015 at 2:27
  • $\begingroup$ what are you saying. i dont get it $\endgroup$
    – Bilal Ayub
    Sep 19, 2015 at 9:11
3 Answers 3
It should be completely safe. Assuming that the 5V BEC on the ESC is not damaged then it is providing a regulated voltage to your Arduino. Furthermore, the USB port on the Arduino is protected from back current with Zener diodes, thus protecting whatever may be plugged into that port.
please see: https://dronesandrovs.wordpress.com/?attachment_id=241#main
It looks like it's safe.
  • $\begingroup$ Can you summarize the important parts from the link? Links tend to rot. $\endgroup$
    – Mark Omo
    Sep 23, 2015 at 20:12
See this answer to similar question on the EE Stack Exchange:
The official stance on supplying power directly to the 5V pin on the Arduino Uno is thus:
Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.
5
  • $\begingroup$ the 5v can support input on 5v pin as well as output 5v when other supply is connected. i think you are confusing in thins $\endgroup$
    – Bilal Ayub
    Sep 18, 2015 at 19:04
  • $\begingroup$ the esc.s power the motor but for motors they have other two wires, red and black color larger crosssection wires. i am not using them, i am getting the 5v power,. this 5v is not given to motors $\endgroup$
    – Bilal Ayub
    Sep 18, 2015 at 19:12
  • $\begingroup$ that is it now? $\endgroup$
    – Bilal Ayub
    Sep 18, 2015 at 19:23
    $\begingroup$ Most ESC's have a BEC. The OP is really talking about providing power to the Arduino via the 5V BEC circuit included in the ESC circuitry. Everything after the EDIT is irrelevant. Also, the BEC is another regulated 5V source, so it should be safe. $\endgroup$
    – Octopus
    Sep 21, 2015 at 20:09
  • $\begingroup$ @Octopus - I understand what you're saying. I couldn't tell from OP's post how everything was connected. The statement "I have esc,s connected to it which arnt likely to start in other cases" made it seem to me like OP was trying to somehow use USB power for the ESC, but then I thought OP was trying to connect ESC output or the battery directly to the 5V port, and none of those cases would work. $\endgroup$
    – Chuck
    Sep 21, 2015 at 20:17
