Hi,
I am currently doing a school project where we were given the task to "simulate" a welding path using a UR5. Since the welding path has to be very precise we have created a path containing around 700 waypoints that the arm has to go through. Initially we tried simply defining every single pose using Eigen::Affine3d and Eigen::Quaterniond, for instance this is our first waypoint.
Eigen::Affine3d pose1= Eigen::Translation3d(0.618794, 0.02779, 0.1482) * Eigen::Quaterniond(0.4815, 0.1315, -0.8665, 0);
Following defining all 700 of these poses we would simply do
group.setPoseTarget(pose1);
group.move();
group.setPoseTarget(pose2);
group.move();
and so on.
Now this probably has a number of disadvantages, but the most apparent one is that when running this program on a real UR5, the motors stop after every group.move which means that there is a LOT of stuttering.
My question is:
Is there a way to compute a path with all of these waypoints included? And can this path then be executed in one fluid motion? If this is not possible using MoveIt, is there another way to do it within ROS? We really want to use ROS for this, but watching other groups use "simple" simulation software to execute their paths is rather disheartening and makes us want to go for the "easy" solution.
We are currently running ROS Indigo on Ubuntu 14 using ROS Industrial for simulation and the Modern UR driver for when connecting to the UR5.
Any help is appreciated and please tell me if i need to explain anything further.
Originally posted by Matziieee on ROS Answers with karma: 23 on 2017-05-09
This is certainly possible, but as you found out, group.move() is probably not the best way to do this: group.move() assumes that you want to move your EEF, while avoiding collisions, through an unstructured / semi-structured scene to a single destination. That requires motion planning, which is a (relatively) complex process. On top of that, each .move() is considered a separate request, with smoothness only 'guaranteed' between start and goal of the motion, not between subsequent requests. The fact that you submit a lot of goals, one after the other, does not make MoveIt 'realise' that you want something it isn't doing: you're sending it separate requests, so MoveIt generates a lot of (very short) trajectories for you, just as you ask.
This is where your 'stuttering' is coming from.
The "simple" simulation software that you are referring to is probably either a CAD-to-path (c2p) or a kinematic playout tool (RoboDK by any chance?), not a simulation per se. These essentially generate either a single motion through all waypoints, or use something called blending to make subsequent motions smoothly follow each other. This blending is typically done by the controller, not the software generating the robot program.
As useful as those c2p tools are, it's slightly unfair to compare what they are doing to what MoveIt is doing: the latter is a complete planning pipeline, able to deal with (almost) arbitrarily complex kinematic setups and environments, with a focus on getting your EEF to your goal pose without colliding with anything. The former typically 'only' do pose interpolation based on waypoints generated from workpiece geometry without any regard for your robot, your tool or your environment (this is changing though).
Getting a single, continuous path out of MoveIt is possible however: you could take a look at the Cartesian Path capabilities which essentially allow you to provide a list of waypoints and plan (really: iterate) through all of them at once. See Move Group Interface Tutorial - Cartesian Paths for an impression on how to do this.
Another option would be to look at a planner such as Descartes: that is a slightly different approach, but well suited for these type of tasks. There is currently some interest over at the ROS-Industrial mailing list to extend the tutorials of Descartes with some more info on how it could be used for something like welding. See Descartes path planning extra tutorial.
Note btw that to successfully weld something you would most likely also need synchronised (de)activation of your EEF / other peripherals. Neither MoveIt nor Descartes will do this for you. Good welding is actually not trivial and includes much more than just planning a smooth motion through a nr of waypoints.
Originally posted by gvdhoorn with karma: 86574 on 2017-05-09
Post score: 8
Comment by Matziieee on 2017-05-09:
Thank you so much for your help. I am going to look into both Cartesian paths and Descartes and find out which i prefer. On another note I would like to thank you for everything you've done for the community in general! Your posts have already helped me multiple times and I appreciate it a lot :)
Also another question (sorry if I am nagging) can i still use my quaternions or will i have to convert them to the format used in the cartesian path tutorial?
Comment by gvdhoorn on 2017-05-09:
computeCartesianPath(..) accepts a vector of geometry_msgs/Pose, so that is still a Point with a Quaternion.
Thank you. Appreciate the help a lot.
Be aware that computeCartesianPath(..) is a tricky / sensitive function in MoveIt. Success depends heavily on having a good IK solver plugin configured for your setup, and on the parameters that you give it. Don't be discouraged if at first things don't seem to work.
But for any realistic welding, I'd look at Descartes.
Comment by pmuthu2s on 2018-01-06:
Hey guys, with descartes, is it possible to control the velocity in cartesian space?
Comment by gvdhoorn on 2018-01-06:
This would've been better as a separate question, but to answer it here: no, Descartes is a path planner, not a trajectory generator. See ros-industrial-consortium/descartes#148 for some related discussion.
