The code is as follows:
#include "ros/ros.h"
#include "std_msgs/String.h"
#include "sensor_msgs/JointState.h"
#include <sstream>
class SubscribeAndPublish
public:
    SubscribeAndPublish()
            //topic you want to publish
            pub_=n.advertise<sensor_msgs::JointState>("/arm/joint_states",1000);
            //subscribe
            sub_=n.subscribe("/joint_states",1000,&SubscribeAndPublish::callback,this);
    void callback(const sensor_msgs::JointState::ConstPtr& msg)
            sensor_msgs::JointState output;
            output.name=msg->name;  //  output.name[0]="Tjoint
            output.position=msg->position;
            output.header=msg->header;
            pub_.publish(output);
private:
    ros::NodeHandle n;
    ros::Publisher pub_;
    ros::Subscriber sub_;
    ros::init(argc, argv, "talker");
    SubscribeAndPublish SAPobject;
    ros::spin();
    return 0;
Originally posted by buaawanggg on ROS Answers with karma: 1 on 2017-05-03
Comment by gvdhoorn on 2017-05-03:
This is not a question.
Please format your code properly (use the Preformatted text button) and explain what you are trying to do, what doesn't work and why you think that doesn't work.
Comment by buaawanggg on 2017-05-03:
thx for your advice ,i try to write a node to subscribe the topic “joint-states” , this topic have messages of 6 joints ,but what i need is only the message of “joint0” and publish the message of “joint0” to topic “arm/joint_states”
i want to use the “void callback“” to filter the message
Comment by jarvisschultz on 2017-05-04:
I've provided an answer to your question, and reformatted your original question. I was only able to do this because I had already answered your original question; so I knew what you were asking. As @gvdhoorn indicated, please put more effort into writing clear and nicely formatted questions
You can't call output.name[0] without first allocating at least one entry in the std::vector<std::string> data that is the output.name field. You should likely use something like std::vector::push_back or std::vector::resize to allocate the memory. The same is true for the position field.
Here's a quick rewrite of your callback as an example:
    output.header = msg->header;
    // create space for our single joint name and position:
    output.name.resize(1);
    output.position.resize(1);
    // find correct joint and store in output:
    std::vector<std::string>::const_iterator name_it = msg->name.begin();
    std::vector<double>::const_iterator position_it = msg->position.begin();
    for (; name_it != msg->name.end() && position_it != msg->position.end(); ++name_it, ++position_it)
        if ( (*name_it).compare("joint1") == 0)
            // then we've found the joint!
            output.name[0] = *name_it;
            output.position[0] = *position_it;
            break;
    return;
Originally posted by jarvisschultz with karma: 9031 on 2017-05-04
