I want to add a fixed placed at the same location of the camera_frame. The camera is attached to the robot and so is the camera_frame. However the frame moves along with the robot. I can add a static frame camera_frame_fixed at the location using a ROS node. The node would listen to the transform between the odom and camera _frame once, store the values, and then publish a static transform between odom and the camera_frame_fixed using these values. Is there another way to do this without creating a ros node?
Originally posted by hc on ROS Answers with karma: 114 on 2017-05-02
As you might know, you can always quickly publish tf transforms via the static transform publisher:
rosrun tf static_transform_publisher 0.2 0.1 0.0 0.0 0.0 0.0 base_link camera_frame 1000
That being said, your application sounds rather specialized, so I don't think you'll get around writing a small Python node for achieving what you want.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2017-05-02
Comment by hc on 2017-05-02:
Writing the node is easy. As I state in the sub question, that method exists. And I have done that before. Is there some other way to add it? The static transform requires values to be known. And they must somehow be read once, stored and substituted.
