I'm using the rosarduino bridge package on a custom robot and i'm developing a node access the package when required. but im havin trouble callin the services in arduinobridge usin rospy.serviceproxy(' ', )
shld it be called usin another function in da client node.. i did add da dependacies in da node.
This is da code I used to call the service
#!/usr/bin/env python
import sys
import rospy
from ros_arduino_python import *
from ros_arduino_msgs.srv import *
def digital_write_client(pin, value):
  # rospy.wait_for_sevice('digital_write')
   try:
        digital_write = rospy.ServiceProxy('digital_write', DigitalWrite)
        digital_write(pin,value)
        print"call success"
   except rospy.ServiceException, e:
        print "Service call failed: %s"%e
if __name__ == "__main__":
   digital_write_client(8,1)
Originally posted by maxsteel777 on ROS Answers with karma: 16 on 2017-04-21
Comment by ahendrix on 2017-04-21:
Which service are you trying to call? What happens when you try to call it? Do you get a python stack trace?
Comment by maxsteel777 on 2017-04-21:
i'm tryin to call DigitalWrite.srv using the below code, but i keep gettin da exception i have implemented. I'm new to ROS so having trouble
try: digital_write = rospy.ServiceProxy('digital_write', DigitalWrite) digital_write(pin,value)
Comment by ahendrix on 2017-04-22:
Please edit your question with the full program that you're trying to run, and the full exception that you get.
I found da error in the code. I had been usin the wrong service name (rospy.ServiceProxy('digital_write', DigitalWrite). I changed it to 'arduino/digital_write' and its workin fine. Thank you
Originally posted by maxsteel777 with karma: 16 on 2017-04-22
