Hi everyone
I have a question about spawning model by using spawn_model service. I use .xacro file for descripting the hector_quadrotor model. And I need to dynamically spawning new model by calling spawn_model service. But I feel confused about how to use .xacro file as parameter for the model_xml fild of gazebo_msgs/SpawnModel message type.If conversion is necessary, does anyone know how to conver .xacro to .urdf or .xml in c++ code.
Thanks
Originally posted by [email protected] on ROS Answers with karma: 31 on 2017-04-21
Xacro files need to be parsed by the xacro parser before you can load them into Gazebo, rViz, etc.
When you are running things through a launch file, you can do this easily at launch time, like the example below. But if you are using the file from a node, it's easier to run xacro first to produce an output that you save to a file and work with that processed file.
<param name="robot_description" command="$(find xacro)/xacro.py '$(find my_robot_description)/urdf/my_robot.urdf.xacro' "/>
Originally posted by Geoff with karma: 4203 on 2017-04-23
