Good morning people
I did a listener for the camera/image_raw node republish (camera/image_test, but the following error appears: Client [/ QR_Listener_5598_1492006578702] wants topic /camera/image_test to have datatype/md5sum [std_msgs /String/992ce8a1687cec8c8bd883ec73ca41d1], but our version has [sensor_msgs/Image/060021388200f6f0f447d0fcd9c64743]. Dropping connection.
Follow the listener code:
#!/usr/bin/env python
import rospy
import cv2
import zbar
from PIL import Image
def callback(data):
    scanner = zbar.ImageScanner()
    scanner.parse_config('enable')
        ret, output = data.read()
        if not ret:
            continue
        gray = cv2.cvtColor(output, cv2.COLOR_BGR2GRAY, dstCn=0)
        pil = Image.fromarray(gray)
        width, height = pil.size
        raw = pil.tobytes()
        image = zbar.Image(width, height, 'Y800', raw)
        scanner.scan(image)
        qrc = None
        for symbol in image:
            print '"%s"' % symbol.data
            qrc = symbol.data
        qrc
        cv2.imshow("#Qr Code", output)
        if qrc != None:
            rospy.loginfo(rospy.get_caller_id() + "Qr Code %s:", data.data)
def listener():
    rospy.init_node('QR_Listener', anonymous=True)
    rospy.Subscriber("/camera/image_test", String, callback)
    rospy.spin()
if __name__ == '__main__':
    try:
        listener()
    except rospy.ROSInterruptException:
        pass
Originally posted by icarold on ROS Answers with karma: 5 on 2017-04-12
The answer is already in the error message: You create a std_msgs::String subscriber to listen to an sensor_msgs::Image message.
So it should be
from sensor_msgs.msg import Image
 rospy.Subscriber("/camera/image_test", Image, callback)
Originally posted by NEngelhard with karma: 3519 on 2017-04-12
Comment by icarold on 2017-04-12:
Many thanks, my friend !! Lack of attention to mine. I'll test here
The command did not work:
from visualization_msgs.msg import Image
ImportError: cannot import name Image
Comment by jarvisschultz on 2017-04-12:
@icarold You should not add an answer that is not really an answer. If you need to add information, please edit your original question. I've moved your answer to be a comment.
The error described in your comment is because the visualization_msgs package doesn't have a message called Image (it has ImageMarker). My guess is that you are actually looking for the sensor_msgs/Image message type.
Comment by NEngelhard on 2017-04-13:
sorry, it's of course in sensor_msgs, fixed it
Comment by icarold on 2017-04-13:
I used the sensor_msgs.msg import image as suggested, but now it is giving no error data.read().
File "/home/icaro/catkin_ws/src/tcc/scripts/listener_qr.py", line 14, in callback
     Ret, output = data.read ()
AttributeError: 'Image' object has no attribute 'read'
If I take the read() error in the:
ret, output = data
TypeError: 'Image' object is not iterable
why do you think that an Image-object has a read-function? http://wiki.ros.org/cv_bridge/Tutorials/ConvertingBetweenROSImagesAndOpenCVImagesPython
Thanks friends for the help!! NEngelhard, this link that you sent helped me and it worked, I managed to do !! Thank you
great! then please mark the answer as correct so that the question can be closed
