I followed the instructions given at the frontier_exploration wiki page:
http://wiki.ros.org/frontier_exploration#For_running_a_demo
roslaunch navigation_stage move_base_gmapping_5cm.launch
roslaunch navigation_stage move_base.xml
roslaunch frontier_exploration global_map.launch
After I specified an exploration region in rviz, the robot will start exploring but soon it will stops.
From the rviz and stage, I observed that the robot most of the times got stuck to some obstacle and failed to recover, but sometimes it was in a open space, not close to any obstacle, and still couldn't move.
In the frontier_exploration terminal, I always saw an error message:
[ERROR] [1491936923.242211778, 124.600000000]: Failed to move
In the move_base terminal, I saw a related error message when the robot got stuck:
[ERROR] [1491936126.596561945, 221.100000000]: Aborting because a valid plan could not be found. Even after executing all recovery behaviors
Has anyone else encounter a similar issue? Do I need to change some configurations/parameters of move_base and exploration_frontier? Any suggestion or help will be highly appreciated.
Originally posted by renweiros on ROS Answers with karma: 36 on 2017-04-11
I found one possible cause for this issue. The footprint config in navigation_stage/move_base_config/costmap_common_params.yaml doesn't match the sample config in frontier_exploration/launch/global_map.launch.
The footprint config in costmap_common_params.yaml:
#The footprint of the robot and associated padding
footprint: [[-0.325, -0.325], [-0.325, 0.325], [0.325, 0.325], [0.46, 0.0], [0.325, -0.325]]
footprint_padding: 0.01
The footprint config in global_map.launch:
footprint: [[0.1, 0.0], [0.0, 0.1], [-0.1, 0.0], [0.0, -0.1]]
robot_radius: 0.10
I tried changing the one in global_map.launch to match the one in costmap_common_params.yaml and started getting better results, i.e., the exploration won't fail quickly. But the exploration will often fail because the robot can't move, especially when it tries exploring a relatively large unknown area. Does anyone have any suggestion? Many thanks in advance.
Originally posted by renweiros with karma: 36 on 2017-04-14
