Hello,
I've gone through the turtlesim movement tutorials and they've helped a lot but I'm unable to get the script to continuously ask me for inputs for 1 minute and execute the movements. I've tried to use a while loop but it doesn't seem to work. When I Ctrl-C the terminal running the script it'll continuously ask me for inputs but the turtle doesn't move. How would I change the python code to have it asks me for inputs more than once and move the turtle multiple times without having to rerun the script?
The code I used is shown below:
#!/usr/bin/env python
import rospy
from geometry_msgs.msg import Twist
import time
def move():
    # Starts a new node
    rospy.init_node('robot_cleaner', anonymous=True)
    velocity_publisher = rospy.Publisher('/turtle1/cmd_vel', Twist, queue_size=10)
    vel_msg = Twist()
    #Receiveing the user's input
    print("Let's move your robot")
    speed = input("Input your speed:")
    distance = input("Type your distance:")
    isForward = input("Foward?: ")#True or False
    #Checking if the movement is forward or backwards
    if(isForward):
        vel_msg.linear.x = abs(speed)
    else:
        vel_msg.linear.x = -abs(speed)
    #Since we are moving just in x-axis
    vel_msg.linear.y = 0
    vel_msg.linear.z = 0
    vel_msg.angular.x = 0
    vel_msg.angular.y = 0
    vel_msg.angular.z = 0
        #Setting the current time for distance calculus
        t0 = rospy.Time.now().to_sec()
        current_distance = 0
        #Loop to move the turtle in an specified distance
        while(current_distance < distance):
            #Publish the velocity
            velocity_publisher.publish(vel_msg)
            #Takes actual time to velocity calculus
            t1=rospy.Time.now().to_sec()
            #Calculates distancePoseStamped
            current_distance= speed*(t1-t0)
        #After the loop, stops the robot
        vel_msg.linear.x = 0
        #Force the robot to stop
if __name__ == '__main__':
     try:
         timeout =  time.time() + 60
         while time.time() < timeout:
             move()
     except rospy.ROSInterruptException:
         pass
Originally posted by SupermanPrime01 on ROS Answers with karma: 27 on 2017-04-09
A simple working solution is the following:
import rospy
import time
def move(velocity_publisher):
    vel_msg = Twist()
    if(isForward):
    else:
    # Starts a new node
    try:
     pass
As of why your implementation is not working, you use while not rospy.is_shutdown(): inside the move function and you are preventing it from returning, since this while loop will stop only when the node is killed. Also notice that the node and publisher definitions are in main and not in the move function. We do not want to define those everytime we call the move function.
Originally posted by gstavrinos with karma: 641 on 2017-04-10
Comment by SupermanPrime01 on 2017-04-10:
Thank you for providing the code. When people explain it to me, I have trouble visualizing it in my mind. Thankfully, you've provided the code and I can match the code with your description.
