I would like to create a map of a topic name to a template function that constructs a message in the context of publishing to a topic. Essentially I would be following the pattern described in this SO post.
However, the caveat is that the objects need to share a parent class. I was looking at the header files and it doesn't seem to be the case, but perhaps there is something that I don't see.
Is there a shared parent class for all messages?
Originally posted by cpagravel on ROS Answers with karma: 156 on 2017-03-30
Yes, for Python code, see https://github.com/ros/genpy/blob/cb07134e084a4fb6099de5cefcbb6b9a7f666cf5/src/genpy/message.py#L269
No, for C++ code, see https://github.com/ros/gencpp/blob/90a850954f7dec3d7274b4fc36d35b1fe6676b22/scripts/msg.h.template#L62
Originally posted by Dirk Thomas with karma: 16276 on 2017-03-30
Comment by cpagravel on 2017-03-30:
That's what I gathered as well from looking at the header files, but I had hoped I overlooked something. Is there a way to change this without breaking anything?
Comment by Dirk Thomas on 2017-03-30:
Well, you could change the C++ template locally and rebuild all of ROS from source to utilize it. But your code using that would be incompatible with "normal" ROS packages.
Can I suggest this for the future ROS versions? It's a small change to make.
Please see why a base class has been removed in the first place: http://answers.ros.org/question/199829/why-ros-messages-do-not-inherit-from-a-base-class/
