I am trying to use the ukf node in the robot_localization but this node is not publishing the transform from the frame map to odom and the following error message appear: Could not obtain transform from odom to map. Error was "map" passed to lookupTransform argument target_frame does not exist. My config file is the following:
frequency: 30
sensor_timeout: 0.1
two_d_mode: true
transform_time_offset: 0.0
transform_timeout: 0.0
print_diagnostics: true
debug: false
debug_out_file: ~/.ros/robot/rDebug.log
map_frame: map
odom_frame: odom
base_link_frame: base_link
world_frame: map
odom0: odom
odom0_config: [true,  true,  false,
               false, false, true,
               false, false, false,
               false, false, false]
odom0_queue_size: 2
odom0_nodelay: false
odom0_differential: false
odom0_relative: false
odom0_pose_rejection_threshold: 5
odom0_twist_rejection_threshold: 1
pose0: pose
pose0_config: [true,  true,  false,
               false, false, true,
pose0_differential: true
pose0_relative: false
pose0_queue_size: 5
pose0_rejection_threshold: 2
pose0_nodelay: false
use_control: true
stamped_control: false
control_timeout: 0.2
control_config: [true, false, false, false, false, true]
acceleration_limits: [1.3, 0.0, 0.0, 0.0, 0.0, 3.4]
deceleration_limits: [1.3, 0.0, 0.0, 0.0, 0.0, 4.5]
acceleration_gains: [0.8, 0.0, 0.0, 0.0, 0.0, 0.9]
deceleration_gains: [1.0, 0.0, 0.0, 0.0, 0.0, 1.0]
process_noise_covariance: [0.05, 0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0.05, 0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0.06, 0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0.03, 0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0.03, 0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0.06, 0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0.025, 0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0.025, 0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0.04, 0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0.01, 0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0.01, 0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0.02, 0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0.01, 0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0.01, 0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0.015]
initial_estimate_covariance: [1e-9, 0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    1e-9, 0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    1e-9, 0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    1e-9, 0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    1e-9, 0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    1e-9, 0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    1e-9, 0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    1e-9, 0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    1e-9, 0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    1e-9,  0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     1e-9,  0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     1e-9,  0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     1e-9, 0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    1e-9, 0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    1e-9]
alpha: 0.001
kappa: 0
beta: 2
My inputs are odometry and a PoseWithCovarianceStamped. The frame_ids in the message does not have slashes. Odometry/filtered is not being published as well. All other transformations are okay including odom->base_link. What am I doing wrong? Is it possible to use the robot_localization package having a known map and a laser scan?
Update:
I am using the differential drive gazebo plugin to generate the odom->base_link transform.
Input_messages:
Odometry input message:
header:
  seq: 346
  stamp:
    secs: 34
    nsecs: 723000000
  frame_id: odom
child_frame_id: base_link
pose:
  pose:
    position:
      x: 3.09824971028e-06
      y: -4.12930698334e-11
      z: 0.0
    orientation:
      x: 0.0
      y: 0.0
      z: -0.000308331906876
      w: 0.999999952466
  covariance: [1e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.001]
twist:
  twist:
    linear:
      x: -6.59023772555e-06
      y: 4.06376386433e-09
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: -6.0041686542e-05
  covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
Pose input message:
header:
  seq: 88
  stamp:
    secs: 110
    nsecs:  20000000
  frame_id: odom
pose:
  pose:
    position:
      x: 0.0339823272081
      y: -0.0283254735522
      z: 0.0
    orientation:
      x: 0.0
      y: 0.0
      z: -0.000438910551745
      w: 0.999999903679
  covariance: [1.4186971384333447e-05, -2.3090090053301537e-06, 0.0, 0.0, 0.0, 0.0, -2.309008550582803e-06, 1.7632721210247837e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1.844621237978572e-06, 0.0, 0.0, 0.0, 0.0, 0.0, -3.6789799651160138e-06, 0.0, 0.0, 0.0, 1.844621237978572e-06, -3.678979510368663e-06, 2.932679535661009e-06]
Originally posted by agbj on ROS Answers with karma: 83 on 2017-03-29
Comment by Tom Moore on 2017-04-11:
Can you please change the formatting of your config file to use the code formatting (tiny box with ones and zeros)? Also, please post a sample message from every input. What are you using to generate the odom->base_link transform?
Your question is already answered here:
Using robot_localization with amcl
Originally posted by Orhan with karma: 856 on 2017-04-07
Comment by agbj on 2017-04-10:
Thank you for the answer but to publish both the pose and odometry in the same frame to get the transform from map to odom. I think i have to publish the odometric information in the map frame. Correct me if I am wrong. But the node that publishes the odometry does not know how to transform the pose
Comment by Orhan on 2017-04-10:
That thing explained in the link above. If you tune correctly (remappings etc.) It publishes transforms between frames automatically.
The frame between map and odom is being published by the ukf node, but it is incorrect because in rviz the robot just stands still and i think it is because I am publish both the pose and odometry in the odom frame. When I use only my localization node the robot is able to localize itself reasonably
