Hello, I'm trying to install the tim_sumulator and I followed this guide for ros indigo https://github.com/dougvk/tum_simulator. Instead of creating a new workspace I downloaded the dependencies in my catkin_src/src directory. Now when I try to "catkin_make" while in the "catkin_ws" directory, I get this error Invoking "make -j8 -l8" failed
The following is what I get from the terminal:
Base path: /home/jtu/catkin_ws Source space: /home/jtu/catkin_ws/src Build space: /home/jtu/catkin_ws/build Devel space: /home/jtu/catkin_ws/devel Install space: /home/jtu/catkin_ws/install
Running command: "make cmake_check_build_system" in "/home/jtu/catkin_ws/build"
Running command: "make -j8 -l8" in "/home/jtu/catkin_ws/build"
[ 0%] Built target geometry_msgs_generate_messages_py [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_RawImu [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_AttitudeCommand [ 0%] [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_RuddersCommand Built target _cvg_sim_msgs_generate_messages_check_deps_HeightCommand [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_RawRC [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_PositionXYCommand [ 0%] [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_ServoCommand Built target _cvg_sim_msgs_generate_messages_check_deps_MotorCommand [ 0%] [ 0%] [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_Supply Built target _cvg_sim_msgs_generate_messages_check_deps_ControllerState Built target _cvg_sim_msgs_generate_messages_check_deps_ThrustCommand [ 0%] [ 0%] [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_HeadingCommand Built target _cvg_sim_msgs_generate_messages_check_deps_Altimeter Built target _cvg_sim_msgs_generate_messages_check_deps_VelocityZCommand [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_MotorPWM [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_VelocityXYCommand [ 0%] [ 0%] [ 0%] [ 0%] [ 0%] [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_Altitude Built target geometry_msgs_generate_messages_lisp Built target _cvg_sim_msgs_generate_messages_check_deps_YawrateCommand Built target _cvg_sim_msgs_generate_messages_check_deps_MotorStatus Built target _cvg_sim_msgs_generate_messages_check_deps_Compass Built target _cvg_sim_msgs_generate_messages_check_deps_RC [ 0%] [ 0%] Built target _cvg_sim_msgs_generate_messages_check_deps_RawMagnetic Built target geometry_msgs_generate_messages_cpp [ 0%] Built target std_msgs_generate_messages_lisp [ 0%] Built target std_msgs_generate_messages_cpp [ 0%] Built target std_msgs_generate_messages_py [ 0%] Built target _beginner_tutorials_generate_messages_check_deps_AddTwoInts [ 0%] Built target _beginner_tutorials_generate_messages_check_deps_Num [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_vision_of [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_RecordEnable Built target _ardrone_autonomy_generate_messages_check_deps_navdata_raw_measures [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_kalman_pressure [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_vision Built target _ardrone_autonomy_generate_messages_check_deps_navdata_pwm [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_video_stream Built target _ardrone_autonomy_generate_messages_check_deps_navdata_time [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_vision_detect [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_euler_angles [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_Navdata [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_altitude [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_CamSelect Built target _ardrone_autonomy_generate_messages_check_deps_navdata_rc_references [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_trackers_send [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_vector31 [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_FlightAnim Built target _ardrone_autonomy_generate_messages_check_deps_matrix33 [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_hdvideo_stream [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_references [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_demo [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_vision_perf [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_trims [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_vision_raw Built target _ardrone_autonomy_generate_messages_check_deps_navdata_watchdog [ 0%] [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_wifi Built target _ardrone_autonomy_generate_messages_check_deps_navdata_games Built target _ardrone_autonomy_generate_messages_check_deps_navdata_adc_data_frame [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_zimmu_3000 [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_phys_measures [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_magneto [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_wind_speed [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_gyros_offsets [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_vector21 [ 0%] [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_LedAnim [ 0%] Built target _ardrone_autonomy_generate_messages_check_deps_navdata_pressure_raw Performing update step for 'ardronelib' [ 0%] Built target sensor_msgs_generate_messages_py [ 0%] Built target _eagle_one_test_generate_messages_check_deps_Pid_receive [ 0%] Built target _eagle_one_test_generate_messages_check_deps_Pid2 [ 0%] [ 0%] Built target nav_msgs_generate_messages_py Performing configure step for 'ardronelib' [ 0%] Built target _eagle_one_test_generate_messages_check_deps_Test [ 0%] [ 0%] [ 0%] No configure Built target _eagle_one_test_generate_messages_check_deps_State Built target sensor_msgs_generate_messages_lisp Built target nav_msgs_generate_messages_lisp [ 0%] Built target _eagle_one_test_generate_messages_check_deps_Pid_send [ 0%] [ 0%] Built target _cvg_sim_gazebo_plugins_generate_messages_check_deps_SetBias Built target sensor_msgs_generate_messages_cpp [ 0%] [ 0%] [ 0%] Built target nav_msgs_generate_messages_cpp [ 0%] [ 0%] [ 0%] Performing build step for 'ardronelib' Building CXX object tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_magnetic.dir/src/gazebo_ros_magnetic.cpp.o Building CXX object tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_gps.dir/src/gazebo_ros_gps.cpp.o make[3]: warning: jobserver unavailable: using -j1. Add +' to parent make rule. Building CXX object tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_sonar.dir/src/gazebo_ros_sonar.cpp.o Building CXX object tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/diffdrive_plugin_6w.dir/src/diffdrive_plugin_6w.cpp.o [ 0%] [ 0%] Built target test_trajectory Building CXX object tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/reset_plugin.dir/src/reset_plugin.cpp.o In file included from /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/src/gazebo_ros_gps.cpp:29:0: /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/include/hector_gazebo_plugins/gazebo_ros_gps.h:32:28: fatal error: common/Plugin.hh: No such file or directory #include "common/Plugin.hh" ^ compilation terminated. In file included from /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/src/gazebo_ros_sonar.cpp:29:0: /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/include/hector_gazebo_plugins/gazebo_ros_sonar.h:32:28: fatal error: common/Plugin.hh: No such file or directory #include "common/Plugin.hh" ^ compilation terminated. In file included from /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/src/gazebo_ros_magnetic.cpp:29:0: /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/include/hector_gazebo_plugins/gazebo_ros_magnetic.h:32:28: fatal error: common/Plugin.hh: No such file or directory #include "common/Plugin.hh" ^ compilation terminated. Libs already extracted Building target static In file included from /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/src/reset_plugin.cpp:29:0: /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/include/hector_gazebo_plugins/reset_plugin.h:32:28: fatal error: common/Plugin.hh: No such file or directory #include "common/Plugin.hh" ^ compilation terminated. [ 1%] Built target message_to_tf In file included from /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/src/diffdrive_plugin_6w.cpp:36:0: /home/jtu/catkin_ws/src/tum_simulator/cvg_sim_gazebo_plugins/include/hector_gazebo_plugins/diffdrive_plugin_6w.h:30:28: fatal error: common/Plugin.hh: No such file or directory #include "common/Plugin.hh" ^ compilation terminated. [ 2%] make[2]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_gps.dir/src/gazebo_ros_gps.cpp.o] Error 1 Built target tum_ardrone_gencfg make[1]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_gps.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... make[2]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_sonar.dir/src/gazebo_ros_sonar.cpp.o] Error 1 make[1]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_sonar.dir/all] Error 2 make[2]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_magnetic.dir/src/gazebo_ros_magnetic.cpp.o] Error 1 make[1]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/hector_gazebo_ros_magnetic.dir/all] Error 2 [ 5%] Built target thirdparty make[2]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/reset_plugin.dir/src/reset_plugin.cpp.o] Error 1 make[1]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/reset_plugin.dir/all] Error 2 Architecture x86_64 is already built Creating universal static lib file from architectures x86_64 Build done. Checking required Ubuntu packages ... make[2]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/diffdrive_plugin_6w.dir/src/diffdrive_plugin_6w.cpp.o] Error 1 make[1]: *** [tum_simulator/cvg_sim_gazebo_plugins/CMakeFiles/diffdrive_plugin_6w.dir/all] Error 2 ok. Building ARDroneTool/Lib Building ARDroneTool/Lib [ 5%] Performing install step for 'ardronelib' make[3]: warning: jobserver unavailable: using -j1. Add +' to parent make rule. [ 5%] Completed 'ardronelib' [ 7%] Built target ardronelib make: *** [all] Error 2 Invoking "make -j8 -l8" failed
Thank you in advance.
Originally posted by SupermanPrime01 on ROS Answers with karma: 27 on 2017-03-27
"No such file or directory #include "common/Plugin.hh" " compilation terminated is the cause of your problems.
Looks like you need to download the gazebo source
Mark
Originally posted by MarkyMark2012 with karma: 1834 on 2017-03-28
