Hi, I am trying to get data from ar_pose_markers. I am running the package and I see the topic is refreshing with new data. I am using ar_tools and usb_cam.
I have to make a node that subscribe to this topic and it able to extract the information. I am subscribing to the topic but I can extract the position. This code give me a number but is the same number all the time.
The node code is the following one
#include "ros/ros.h"
#include "std_msgs/String.h"
#include <ar_pose/ARMarkers.h>
int yo=10;
int zo;
int i=0;
void ar_pose_markerCallback(const ar_pose::ARMarkers::ConstPtr& msg)
float xo=0;
ROS_INFO("hello world");
ar_pose::ARMarker ar_pose_marker;
xo=ar_pose_marker.pose.pose.orientation.x;
ROS_INFO("%d", xo);
ros::init(argc, argv, "node_sub");
ros::NodeHandle n;
ros::Rate loop_rate(1);
ros::Subscriber sub = n.subscribe("ar_pose_marker", 1, ar_pose_markerCallback);
while (ros::ok())
ros::spinOnce();
loop_rate.sleep();
} return 0; }
Originally posted by jsoley on ROS Answers with karma: 1 on 2017-03-24
Comment by nlamprian on 2017-03-24:
Notice how you are not assigning anything with the received message msg.
Comment by saikishor on 2017-03-25:
Yes!!! You are not using the message at all!!! You have just declared a variable with that type of message. Now, you try using the msg.
Comment by saikishor on 2017-03-29:
Use this "msg->markers[0]" to fetch data in the function.
Man, like they say, use the msg to get the topic information. I can provide you some notes if you want.
Originally posted by Brijesh GM with karma: 16 on 2017-03-25
