Hi, I am trying to get data from ar_pose_markers. I am running the package and I see the topic is refreshing with new data. I am using ar_tools and usb_cam.
I have to make a node that subscribe to this topic and it able to extract the information. I am subscribing to the topic but I can extract the position. This code give me a number but is the same number all the time.
The node code is the following one
#include "ros/ros.h"
#include "std_msgs/String.h"
#include <ar_pose/ARMarkers.h>
int yo=10;
int zo;
int i=0;
void ar_pose_markerCallback(const ar_pose::ARMarkers::ConstPtr& msg)
float xo=0;
ROS_INFO("hello world");
ar_pose::ARMarker ar_pose_marker;
xo=ar_pose_marker.pose.pose.orientation.x;
ROS_INFO("%d", xo);
ros::init(argc, argv, "node_sub");
ros::NodeHandle n;
ros::Rate loop_rate(1);
ros::Subscriber sub = n.subscribe("ar_pose_marker", 1, ar_pose_markerCallback);
while (ros::ok())
ros::spinOnce();
loop_rate.sleep();
} return 0; }
Originally posted by jsoley on ROS Answers with karma: 1 on 2017-03-24
Comment by angeltop on 2017-03-27:
Try the following:
xo=msg->pose.pose.orientation.x;
You do not use the received data in your code, instead you use the initial value from the constructor of the marker.
Comment by Mikku on 2017-11-23:
Can you write this in Python. Thanks. I wanted to know the current position of my markers and then I have to move my drone to the next way point which is a 3D position.
Comment by angeltop on 2017-11-23:
@Mikku You can follow the tutorial : http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber%28python%29#rospy_tutorials.2BAC8-Tutorials.2BAC8-WritingPublisherSubscriber.Writing_the_Subscriber_Node
Sir I have done that and made my Python file. But I don't want to use callback function. Because when I have to move the drone to the different point . The changes I am doing in the callback function is not being reflected on the main program. I am therefore looking for an another way to find poses.
if you have only using one marker, with your camera try using the below command to fetch x;
msg->markers[0].pose.pose.position.x
if you want orientation, replace "position" with "orientation"
Originally posted by saikishor with karma: 228 on 2017-03-29
