Hello everybody!
I am currently mapping a small tunnel, with about 200m in length and I'm using hector slam with a laser scanner. All working good so far, but with the exception that the map size is not big enough. I have to set the maps size manually via map_size in the launch file before I really know how big the map will be. This may lead to moving outside the map area and not being able to map any further. Setting up a map_size of 20000 etc. is not an option, since it would use up too much space.
Is there a way to dynamically increase the map size?
Cheers and thanks in advance
Bobby
Originally posted by bobbyros on ROS Answers with karma: 11 on 2017-03-23
Try rqt_reconfigure. You should then be able to change parameters dynamically.
Cheers, Goldie
Originally posted by Goldie with karma: 31 on 2017-10-15
Comment by Sj_Nath on 2022-10-12:
When I am running rqt reconfigure, I am not seeing any option for increasing map size. kindly help.
