Hi Guys,
Currently I am a little stuck with my xacro model.
I have a texture file which should be attached to a surface in the xacro. How to add materials to your package, what do I need to export (what could I export) in the package.xml
Where do I really find the stuff documenting this features.
Examples:
            <material>
                <script>
                    <name>a/mat</name>
                    <uri>model://some_model/materials/scripts/mat.material</uri>
                </script>
            </material>
I have seen that for url there can be file and model. Does package also work here? What are those replaced with in the end and which of these exist?
Next: in the material file:
 material a/mat
  technique
    pass
      ambient 0.5 0.5 0.5 1.0
      diffuse 1.0 1.0 1.0 1.0
      specular 0.0 0.0 0.0 1.0 0.5
      texture_unit
        filtering trilinear
From where and how does it know where file.png is?
Does it just go standard for "../textures" ?
Folder structure is mostly like
  • package
    • models
      • myModel
        • textures
        • scripts
It works for me in a sdf file, but it seems to work never in my xacro.
Somehow this is related to the package.xml as well where you export model or media path I found as well:
<export>
  <gazebo_ros gazebo_media_path="${prefix}"/>
</export>
or:
<export>
  <gazebo_ros gazebo_model_path="${prefix}/models"/>
</export>
Are there any others and what exactly do they do?
Which variable does that set? Can I see them in my environment?
How are they supposed to be set up correctly - any standard way?
What if for example I want to do a package with materials for gazebo, which should can be used for any package, how do I set that up?
So that I can use them, as you normally can do with "Gazebo/Grey ", "Gazebo/White"
Example*1 (xacro):
  <gazebo reference="link">
    <material>Gazebo/Grey</material>
  </gazebo>
Can somebody just enlighten me how to do it or where I find the documentation for all these things to make it "just right"?
UPDATE ---
I have now checked out multiple locations and found different places to get information about this thing, also found how to debug it.
http://gazebosim.org/tutorials?tut=ros_roslaunch
there it says:
rospack plugins --attrib="gazebo_media_path" gazebo_ros
And I saw that I actually had a problem. It only takes these if you have a <run _depend> on gazebo_ros.
  <run_depend>gazebo_ros</run_depend>
    <export>
      <gazebo_ros gazebo_media_path="${prefix}/media"/>
    </export>
But I still do not get my material like that*1.
Update 2:
Just when looking at my own old xacros I found out, you can instead of *1 also do:
        <material value="Gazebo/Grey" />
  </gazebo>
So another Question raised up: Which is now the "prefered" way of doing that?
Which one is deprecated?
Thanks a lot,
Regards,
Christian
Originally posted by cyborg-x1 on ROS Answers with karma: 1376 on 2017-03-23
3 Answers 3
This doesn't answer any of your questions, but I avoid all that stuff by just using .DAE files with the material properties embedded in the .dae. I use Blender to create/edit the .dae files and add materials.
Originally posted by Airuno2L with karma: 3460 on 2017-03-23
Comment by cyborg-x1 on 2017-03-23:
hmm, that can be an option as well, I agree
But you can not change a texture by argument with xacro then.
Comment by Airuno2L on 2017-03-23:
Oh I see. I didn't realize that's what you were trying to do. I guess you could just make multiple .dae files of the same object, each with a different material applied.
Well, with meshes in git, that would be a bit of overload, don't you think? ;-) Even there is the fact, that I do not always use meshes. Like for example you can make neat configurable robots like my gantry_bot in my xacro repo
Yeah if you're doing configurable robots using macros I can see why you want to do it this way.
What?
just now it started working like the way I thought it to..
Well in the package.xml you need:
<export>
</export>
and the folder structure is like this:
  • media
    • materials
      • scripts
      • texture
in the xacro file:
<material>YourMaterial</material>
</gazebo>
I guess in the process I changed the folder structure multiple times, maybe I first missed the media folder.
Originally posted by cyborg-x1 with karma: 1376 on 2017-03-24
Comment by praskot on 2020-11-12:
where should the media folder be located?
Actually there is a way to change the texture from within URDF. Put your ".material" file inside /media/materials/scripts/ and your texture images inside /media/materials/textures/. Use this simple snippet for the .material (just to make it simple, your code is right):
material YourMaterialName
   technique
      pass
         texture_unit
          scale 1 1
In your URDF, add the material to the link outside of the tag, but referencing it. Example:
<link name="link_name">
    <inertial>
        <mass value="1.0" />
        <origin xyz="0 0 0" rpy="0 0 0"/>
        <inertia ixx="1e-6" ixy="1e-6" ixz="1e-6"
                 iyy="1e-6" iyz="1e-6"
                 izz="1e-6" />
    </inertial>
    <visual>
        <geometry>
            <mesh filename="full_path_to_your_mesh/mesh.dae"/>
        </geometry>
    </visual>
    <collision>
        <geometry>
            <box size="1 1 1" /> <!-- anything you want... -->
        </geometry>
    </collision>
</link>
<gazebo reference="link_name">
    <material>YourMaterialName</material>
</gazebo>
That's it. If it still doesn't work, then you'll need to prepare your mesh. Open your mesh using Blender, then first imagine how would you cut your solid with a scissor in order to put all surfaces in a plane. Then, select those edges, press Ctrl+E and select Mark Seam. The edges will become red. Split the window into 2 and in the new window choose UV/Image Editor as the Editor Type (bottom left corner). Then, press A to select everything, press U and choose Unwrap. At the UV/Image Editor will appear a geometry showing all your object faces in a plane. Now you can export to COLLADA (.dae) and put in your visual geometry mesh.
If you could not follow up the Blender steps, take a look at this tutorial: https://youtu.be/f2-FfB9kRmE
Post score: 4
is /media/materials/scripts/ absolute path?
