I currently have made my map using Hector Slam and saved the map as .yaml file and .pgm .
I have downloaded the Navigation stack as well using git source: https://github.com/ros-planning/navigation.git . Also ran catkin_make afterwards.
Now, I am trying to implement AMCL by placing my robot( irobot create 2) onto the map and do autonomous mapping.
I am getting an error when i run am amcl file... which says " MapServer could not open <.yaml> file." Please see attached for my code.
Update:
I was able to upload map onto RVIZ, and executed amcl with proper tf/ messages. However, when I move the robot towards a location, the PoseArray points do not move. Please recommend a suggestion. Here is the screen pic. Screenshot from 2017-03-23 14-55-11.png
Originally posted by Shilpan on ROS Answers with karma: 96 on 2017-03-21
Comment by Shilpan on 2017-03-22:
I ran the following commands simultaneously.. roslaunch hector_slam_launch tutorial.launch rosrun map_server map_server .yaml roslaunch amcl amcl_diff.launch
but received message "No laser scan rece
rosrun map_server map_server <file_name>.yaml rosrun rviz rviz --> Add Map->topic /map
Issue resolved. Added tf code messages in AMCL launch file to configure with my robot.
Please see for follow up Q. link text
Originally posted by Shilpan with karma: 96 on 2017-03-24
