Hello, I'm trying to use opencv with ros kinetic. I can run catkin build successfully, but when the method cv::imwrite("image", cv_ptr->image, compression_params); is called, my node dies.
The console shows the following output:
OpenCV Error: Unspecified error (could not find a writer for the specified extension) in imwrite_, file /tmp/binarydeb/ros-kinetic-opencv3-3.2.0/modules/imgcodecs/src/loadsave.cpp, line 531
terminate called after throwing an instance of 'cv::Exception'
what():  /tmp/binarydeb/ros-kinetic-opencv3-3.2.0/modules/imgcodecs/src/loadsave.cpp:531: error: (-2) could not find a writer for the specified extension in function imwrite_
[caltab_detector_node-2] process has died [pid 30212, exit code -6, cmd /home/benny/xenial_ws/devel/lib/caltab_detector/caltab_detector_node caltab_detector_node/image_in:=/webcam/image_raw __name:=caltab_detector_node __log:=/home/benny/.ros/log/2ef1c64e-07d0-11e7-8d74-5c514fc42bc4/caltab_detector_node-2.log].
log file: /home/benny/.ros/log/2ef1c64e-07d0-11e7-8d74-5c514fc42bc4/caltab_detector_node-2*.log
In my C++ node I'm including <opencv2/opencv.hpp>. Is this the correct include for ros kinetic?
My package.xml:
<depend>roscpp</depend>
<depend>cv_bridge</depend>
<depend>sensor_msgs</depend>
My CMakeLists.xml:
project(caltab_detector)
## Make sure HALCONROOT is set
if(NOT DEFINED ENV{HALCONROOT})
  message( FATAL_ERROR "PLEASE SET HALCONROOT" )
endif()
add_definitions(-std=c++11)
find_package(catkin REQUIRED COMPONENTS roscpp cv_bridge sensor_msgs)
find_package(OpenCV 3 REQUIRED)
catkin_package(
  INCLUDE_DIRS include $ENV{HALCONROOT}/include $ENV{HALCONROOT}/include/halconcpp
  CATKIN_DEPENDS roscpp cv_bridge sensor_msgs
include_directories(include $ENV{HALCONROOT}/include $ENV{HALCONROOT}/include/halconcpp  ${catkin_INCLUDE_DIRS} ${OpenCV_INCLUDE_DIRS})
link_directories($ENV{HALCONROOT}/lib/$ENV{HALCONARCH})
add_executable(${PROJECT_NAME}_node src/caltab_detector_node.cpp)
add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(${PROJECT_NAME}_node
   halconcpp
   halcon
   X11
   ${catkin_LIBRARIES}
   ${OpenCV_LIBRARIES}
Originally posted by bennypi on ROS Answers with karma: 48 on 2017-03-13
As The exception says: no writer For File Type. Acutally no File type in your case. Make "image" an e.g. "image.png" to tell opencv to save the File in png format
Originally posted by Wolf with karma: 7555 on 2017-03-13
