Hi, I am using ROS kinetic and since the tutorials on http://wiki.ros.org/hector_quadrotor/Tutorials/Quadrotor%20outdoor%20flight%20demo is a littile bit out-dated, I followed the answer in http://answers.ros.org/question/244776/is-it-possible-to-run-the-hector_quadrotor-demos-in-kinetic/.
It did compile and roslaunch the demo successfully. I've checked the rostopic list and found there is actually a topic called /cmd_vel. I tried to use this command to let the quadrotor take-off
rostopic pub -r 10 /cmd_vel geometry_msgs/Twist  '{linear:  {x: 0, y: 0.0, z: 1.0}, angular: {x: 0.0,y: 0.0,z: 0.0}}'
But the quadrotor still stays on the ground. I used
rostopic echo /cmd_vel
to check if the message is sent to the topic correctly, and it does.
Does someone know what can be possibly wrong?
Originally posted by Kent on ROS Answers with karma: 140 on 2017-03-09
You should first enable motors
rosservice call /enable_motors true
more information in https://github.com/tu-darmstadt-ros-pkg/hector_quadrotor/issues/66
Originally posted by danielponsa with karma: 16 on 2017-05-05
