Hey,
I wish to learn ros and I started by doing the tutorials available on ros.org.
But in the "Writing a Simple Service and Client" tutorial, when it say to modify the file ~/catkin_ws/src/beginner_tutorials/CMakeLists.txt
. I modified the secure file that is in ~/catkin_ws/src
using sudo gedit CMakeLists
. Before that, it worked but now I have a mistake when I do catkin_make
CMake Error at /opt/ros/kinetic/share/genmsg/cmake/genmsg-extras.cmake:94 (message): add_message_files() directory not found: /home/audensiel/catkin_ws/src/msg
Call Stack (most recent call first): CMakeLists.txt:9 (add_message_files)
-- Configuring incomplete, errors occurred! See also "/home/audensiel/catkin_ws/build/CMakeFiles/CMakeOutput.log". See also "/home/audensiel/catkin_ws/build/CMakeFiles/CMakeError.log". Invoking "cmake" failed
When I remove all files and folders and I restart at the beginning (the tutorials), and i created mkdir -p ~/catkin_ws/src
... The file I modified previously is always the same. I think this is my problem, so if someone can give me the contents of this file or tell me how to retrieve the original.
Thank for your help.
William
Originally posted by w.fradin on ROS Answers with karma: 38 on 2017-03-08
