I am running Ubuntu 14.04 and ROS Indigo, and I am quite new to it. I need to use OctoMap: I installed everything from Debians (octomap, octovis etc..). MoveIt! can use the libraries and I can see the the OctoMap in Rviz, but I would like to process it and to select only a specific area of it, accessing the position of each voxel. For this, I guess I would need to use octovis or at least some of the .cpp contained in the octomap package, for seeing some examples on how to filter the map. The problem is that the package that I have under opt/ros/indigo/share is just an empty shell redirecting to the libraries: I see none of the files listed here (https://github.com/OctoMap/octomap), where it is full of examples and .cpp. How can I install/access those files?
Originally posted by HenrySleek on ROS Answers with karma: 53 on 2017-03-03
