Hello together,
I have a question regarding planning with a UR10 arm and Moveit. I try to compute a Cartesian Path around an object. And it frequently happens that the robot can not successfully follow the path until 100%. E.g. it stops after 59% etc. Looking on the control panel for the robot, I noticed that it could not execute the path completely because a joint limit is reached (-2 pi/2 pi). It is a little bit strange to me because normally Moveit should know that it will violate that limit and of course just setting the start state to something around 0 degree would do the job, but it starts for example sometimes with 250 degree for that special joint. Could you help me?
Thank you very much in advance!
Hannes
Originally posted by HannesIII on ROS Answers with karma: 27 on 2017-03-01
