So I am using the Neato Lidar which is 360. However if part of it is blocked, it gets really confused.
Is there a way to tell ROS, don't use angle x to y on this sensor?
Should I just use a Kinect instead?
Originally posted by burf2000 on ROS Answers with karma: 202 on 2017-02-24
Comment by gvdhoorn on 2017-02-25:
See my answer to #q255110.
Comment by burf2000 on 2017-02-25:
Thanks again mate
In #q255110, LaserScanAngularBoundsFilter allows you to change the range start and stop.
The laser_filters package also includes LaserScanAngularBoundsFilterInPlace to remove an arbitrary chuck, instead of changing the start and stop angles.
Example usage:
https://bitbucket.org/DataspeedInc/mobility_base_ros/src/622c06daa4b73ae60ab899e5ecf9ca4aa4e3bbf8/mobility_base_bringup/launch/birdcage_laser_pipeline.launch
https://bitbucket.org/DataspeedInc/mobility_base_ros/src/622c06daa4b73ae60ab899e5ecf9ca4aa4e3bbf8/mobility_base_bringup/yaml/birdcage_laser_filter_params.yaml
Originally posted by kmhallen with karma: 1416 on 2017-02-25
