The default KDL IK solver is still not robust enough. Hence I am planning to use trac_ik.
Instead of keeping the orientation constant throughout the trajectory, I want it to change within specified limits. My question is how to perform orientation constrained based Inverse Kinematics in trac_ik?
Originally posted by ravijoshi on ROS Answers with karma: 1744 on 2017-02-17
I just asked the maintainer on your behalf, who said:
You can't do orientation constraints with the moveit plugin, only when you're using trac_ik_lib directly. As outlined at the bottom of the README, you can specify an orientation (and position) tolerance in the KDL::Twist message provided to ik_solver.CartToJnt(...), which are +/- symmetric.
Hope that helps.
Originally posted by kramer with karma: 1470 on 2017-02-20
Comment by ravijoshi on 2018-06-06:
Can you please answer a related question here?
