[ERROR] [WallTime: 1487314684.230445] Failed to contact device with error: [Distance, angle displacement too big, invalid readings from robot. Distance: 8.20, Angle: 147.45]. Please check that the Create is powered on and that the connector is plugged into the Create.
Originally posted by ICDI on ROS Answers with karma: 1 on 2017-02-17
Comment by Selma B. on 2018-11-19:
Hello,
I have the same problem did you find the solution please.
Thank you in advance.
I think it has something to do with the kobuki base vs the rhoomba base. I am working with a Turtlebot2 with a kobuki base and I got the same error but when I ran roslaunch turtlebot_bringup minimal.launch instead of roslaunch rbx1_bringup turtlebot_minimal_create.launch, everything worked fine.
Originally posted by Eisen with karma: 16 on 2019-06-26
