I am currently running a master node on my Jetson TK1(IP - 10.42.0.15) and a remote PC running ubuntu(IP - 10.42.0.1). I have gone through all the setup shown in the setup and multiple machines. Also, I am able to ping into both of them and netcat results are perfect too. I have also gone through ROS answers on setting up the /etc/hosts file. But, when I try to do the rostopic list after a roscore on tegra ,I just dont see anything.
my setup on tegra is:
export ROS_IP=10.42.0.15
export ROS_HOSTNAME=10.42.0.15
export ROS_MASTER_URI=http://10.42.0.15:11311/
Variables setup on PC are:
Originally posted by kartikmadhira1 on ROS Answers with karma: 121 on 2017-02-11
Comment by epsilonjon on 2017-02-11:
When you run roscore on the master, what is printed to the command line?
Comment by gvdhoorn on 2017-02-11:
This could be roscore binding its socket to the wrong IP, good question @epsilonjon.
Also: @kartikmadhira1: using ROS_IP and ROS_HOSTNAME at the same time is not recommended / necessary. I'd stick to ROS_IP if you are in fact not resolving hostnames.
Comment by kartikmadhira1 on 2017-02-11:
@epsilonjon , The ros master is started with the given IP name and I'm able to run rplidar node too.
@gvdhoorn tried with only ROS_IP, but without any help. messages aren't coming.
@kartikmadhira1 Are you running rplidar and rostopic list on the master or on the other machine?
@epsilonjon rplidar on the master and rostopic list on PC.
Comment by gvdhoorn on 2017-02-12:\
my comment wasn't meant as a "this will solve your problem" kind of comment, but more as a general remark. The semantics of the two variables are different. They shouldn't be used at the same time.
Finally figured it, firewall was at place in the master so did sudo ufw disable to allow port connections and it worked.
Originally posted by kartikmadhira1 with karma: 121 on 2017-02-11
