I'm writing a rqt plugin in python, but can't get the subscriber to work. I want the string from "controller/mode" to show in "lineControlMode". For some reason this doesn't happen. Hope some of you can help me.
import os
import rospkg
import rospy
from qt_gui.plugin import Plugin
from python_qt_binding import loadUi
from python_qt_binding.QtWidgets import QWidget, QGraphicsView
class MyPlugin(Plugin):
def __init__(self, context):
    #PLUGIN CODE
    super(MyPlugin, self).__init__(context)
    # Give QObjects reasonable names
    self.setObjectName('MyPlugin')
    rp = rospkg.RosPack()
    # Process standalone plugin command-line arguments
    from argparse import ArgumentParser
    parser = ArgumentParser()
    # Add argument(s) to the parser.
    parser.add_argument("-q", "--quiet", action="store_true",
                  dest="quiet",
                  help="Put plugin in silent mode")
    args, unknowns = parser.parse_known_args(context.argv())
    if not args.quiet:
        print 'arguments: ', args
        print 'unknowns: ', unknowns
    # Create QWidget
    self._widget = QWidget()
    ui_file = os.path.join(rp.get_path('rqt_vortex_control_mode'), 'resource', 'MyPlugin.ui')
    # Extend the widget with all attributes and children from UI file
    loadUi(ui_file, self._widget)
    self._widget.setObjectName('MyPluginUi')
    # Add widget to the user interface
    context.add_widget(self._widget)
    #MY CODE
    self._widget.lineControlMode.setReadOnly(True)
    self._widget.lineControlMode.setText("init")
    #Subscriber
    self.sub = rospy.Subscriber("/uranus_dp/controller/mode", String, self.callback)
def shutdown_plugin(self):
    self.sub.unregister()
def callback(self, mode):
    self._widget.lineControlMode.setText(mode)
Here is the link to my repository just in case: https://github.com/vortexntnu/rov-gui
Originally posted by fonstein on ROS Answers with karma: 43 on 2017-02-09
Comment by lucasw on 2017-02-11:
The plugin appears to work, but when you publish to /uranus_dp/controller/mode the lineControlMode widget doesn't show anything?
Does the "init" test message successfully show up?
If so then try this at the bottom of the init:
temp = String("test string")
self._widget.lineControlMode.setText(temp)
If that works re-enable the subscriber and put a rospy.loginfo(mode) in the callback and publish test messages to the topic, and see if the callback is getting triggered.
Originally posted by lucasw with karma: 8729 on 2017-02-11
Comment by fonstein on 2017-02-15:
Thanks, that helped a lot. Got it to work now!
Comment by lucasw on 2017-02-15:
What was the issue? Did setText not like taking a String?
I had to cast the data to String. There was also some bugs on the Subscriber, but with your tips on debugging I got it to work.
