I'm a agricultural engineering student and complete newbie trying to build a simple mechanism attached to a drone that dispenses a grease-type fluid. However, since I'm not familiar with the field, I'm having a hard time googling because I don't know the correct terms to search for.
I'm looking for a mechanism that will remotely push the grease out. The problem is carrying the necessary weight for an hectare (300g to 1,5kg of fluid) and the dispenser mechanism within the drone. So I'm looking for a lightweight dispenser mechanism capable of deliver small amounts of this fluid (3g) distributed on the trees canopy. The grease do not need to be heated as it flows naturally in normal temperatures (like a toothpaste). Both pump or syringe-type arrangement would be fine as long as I can control it remotely.
  • $\begingroup$ You say "grease-type fluid". What exactly is it, and will it liquefy/flow at your expected operating temperature? $\endgroup$
    – Chuck
    Aug 17, 2015 at 12:52
  • $\begingroup$ Are you looking for a type of pump or syringe-type arrangement? $\endgroup$ Aug 17, 2015 at 13:15
  • $\begingroup$ On stack exchange, it is better to edit your question to add information requested in comments, rather than adding more comments. Comments are for helping to improve questions and answers, and are distracting, so we try to keep them to a minimum. If all of the information needed to answer the question is contained within it, the comments can be tidied up (deleted), as I've done with your duplicate comment on my answer. $\endgroup$
    – Mark Booth
    Aug 18, 2015 at 22:31
It is difficult to answer your question without more details, but there are a number of design options for pumps, the two most obvious being the Metering pump and the Peristaltic pump.
A Metering pump delivers precise amounts of fluid, but relies on seals which may require ongoing maintenance:
Metering pump head CC-BY-SA
Peristaltic pump is more appropriate for a more continuously pumped fluid, but where metered flow might be needed. It does require your fluid to be appropriate for the flexible pipe needed to make it however:
Peristaltic pump CC-BY-SA
  • $\begingroup$ Good answer, but those may be hard to implement depending on the viscosity of the fluid (grease) to be pumped. It may be possible to put a heater on the fluid reservoir and pump, but as you and I have both mentioned, it's hard to give advice when the problem is so vague! $\endgroup$
    – Chuck
    Aug 17, 2015 at 17:40
It sounds like the simplest option would be to put the grease into a pressurized container (e.g. spring-loaded) and control the metering by just opening and closing the valve. That would mean you just need a solenoid valve to control the opening and closing.
